用于验证 ONTAP 存储配置的 Solaris Host Utilities 命令
您可以使用 Solaris Host Utilities 示例命令参考,通过 Host Utilities 工具对NetApp存储配置进行端到端验证。
列出映射到主机的所有主机启动程序
您可以检索映射到主机的所有主机启动程序的列表。
sanlun fcp show adapter -v
8.0
显示 Solaris Host Utilities 8.0 的示例
adapter name: qlc0 WWPN: 2100f4e9d40fe3e0 WWNN: 2000f4e9d40fe3e0 driver name: qlc model: 7023303 model description: 7101674, Sun Storage 16Gb FC PCIe Universal HBA, QLogic serial number: 463916R+1912389772 hardware version: Not Available driver version: 230206-5.12 firmware version: 8.08.04 Number of ports: 1 of 2 port type: Fabric port state: Operational supported speed: 4 GBit/sec, 8 GBit/sec, 16 GBit/sec negotiated speed: 16 GBit/sec OS device name: /dev/cfg/c4 adapter name: qlc1 WWPN: 2100f4e9d40fe3e1 WWNN: 2000f4e9d40fe3e1 driver name: qlc model: 7023303 model description: 7101674, Sun Storage 16Gb FC PCIe Universal HBA, QLogic serial number: 463916R+1912389772 hardware version: Not Available driver version: 230206-5.12 firmware version: 8.08.04 Number of ports: 2 of 2 port type: Fabric port state: Operational supported speed: 4 GBit/sec, 8 GBit/sec, 16 GBit/sec negotiated speed: 16 GBit/sec OS device name: /dev/cfg/c5
6.2
显示 Solaris Host Utilities 6.2 的示例
adapter name: qlc3 WWPN: 21000024ff17a301 WWNN: 20000024ff17a301 driver name: qlc model: 7335902 model description: 7115462, Oracle Storage Dual-Port 32 Gb Fibre Channel PCIe HBA serial number: 463916R+1720333838 hardware version: Not Available driver version: 210226-5.10 firmware version: 8.08.04 Number of ports: 1 of 2 port type: Fabric port state: Operational supported speed: 8 GBit/sec, 16 GBit/sec, 32 GBit/sec negotiated speed: 32 GBit/sec OS device name: /dev/cfg/c7 adapter name: qlc2 WWPN: 21000024ff17a300 WWNN: 20000024ff17a300 driver name: qlc model: 7335902 model description: 7115462, Oracle Storage Dual-Port 32 Gb Fibre Channel PCIe HBA serial number: 463916R+1720333838 hardware version: Not Available driver version: 210226-5.10 firmware version: 8.08.04 Number of ports: 2 of 2 port type: Fabric port state: Operational supported speed: 8 GBit/sec, 16 GBit/sec, 32 GBit/sec negotiated speed: 16 GBit/sec OS device name: /dev/cfg/c6
列出映射到主机的所有 LUN
您可以检索映射到主机的所有LUN的列表。
sanlun lun show -p -v all
8.0
ONTAP Path: sanboot_unix:/vol/test1/lun1
LUN: 0
LUN Size: 21g
Host Device: /dev/rdsk/c0t600A098038314B314E5D574632365A51d0s2
Mode: C
Multipath Provider: Sun Microsystems
Multipath Policy: Native
6.2
ONTAP Path: data_vserver:/vol1/lun1
LUN: 1
LUN Size: 10g
Host Device: /dev/rdsk/c0t600A0980383044485A3F4E694E4F775Ad0s2
Mode: C
列出从给定 SVM/ 映射到主机的所有 LUN 列出映射到主机的给定 LUN 的所有属性
您可以从特定 SVM 检索映射到主机的所有 LUN 的列表。
sanlun lun show -p -v <svm_name>
8.0
LUN: 0
LUN Size: 20g
Mode: C
6.2
ONTAP Path: sanboot_unix:/vol/sol_boot/sanboot_lun
LUN: 0
LUN Size: 180.0g
按主机设备文件名列出ONTAP LUN属性
您可以通过指定主机设备文件名来检索所有ONTAP LUN属性的列表。
sanlun lun show all
8.0
controller(7mode/E-Series)/ device
vserver(cDOT/FlashRay) lun-pathname filename
sanboot_unix /vol/test1/lun1 /dev/rdsk/
host adapter protocol lun size product
qlc1 FCP 20g cDOT
6.2
controller(7mode/E-Series)/ device vserver(cDOT/FlashRay) lun-pathname filename --------------------------------------------------------------------------------------------------------------- sanboot_unix /vol/sol_193_boot/chatsol_193_sanboot /dev/rdsk/c0t600A098038304437522B4E694E4A3043d0s2 host adapter protocol lun size product --------------------------------------------- qlc3 FCP 180.0g cDOT
