适用于 ONTAP 存储配置的 HP-UX Host Utilities 命令
使用 HP-UX Host Utilities 6.0 示例命令参考,通过 Host Utilities 工具对ONTAP存储配置进行端到端验证。
列出映射到主机的所有主机启动程序
检索映射到主机的所有主机启动器的列表。
sanlun fcp show adapter -v
显示示例输出
adapter name: fclp2 WWPN: 10000000c985ef92 WWNN: 20000000c985ef92 driver name: fclp model: AJ763-63001 model description: HP 8Gb Dual Channel PCI-e 2.0 FC HBA serial number: MY19034N9U hardware version: 3 driver version: @(#) FCLP: PCIe Fibre Channel driver (FibrChanl-02), B.11.31.1805, Feb 5 2018, FCLP_IFC (3,2) firmware version: 2.02X2 SLI-3 (U3D2.02X2) Number of ports: 1 of 2 port type: Unknown port state: Link Down supported speed: 8 GBit/sec negotiated speed: Speed not established OS device name: /dev/fclp2 adapter name: fclp3 WWPN: 10000000c985ef93 WWNN: 20000000c985ef93 driver name: fclp model: AJ763-63001 model description: HP 8Gb Dual Channel PCI-e 2.0 FC HBA serial number: MY19034N9U hardware version: 3 driver version: @(#) FCLP: PCIe Fibre Channel driver (FibrChanl-02), B.11.31.1805, Feb 5 2018, FCLP_IFC (3,2) firmware version: 2.02X2 SLI-3 (U3D2.02X2) Number of ports: 2 of 2 port type: Unknown port state: Link Down supported speed: 8 GBit/sec negotiated speed: Speed not established OS device name: /dev/fclp3
列出映射到主机的所有 LUN
检索映射到主机的所有 LUN 的列表。
sanlun lun show -p -v all
显示示例输出
ONTAP Path: vs_hp_cluster:/vol/chathpux_217_vol_en_1_10/hp_en_217_lun
LUN: 55
LUN Size: 15g
Host Device: /dev/rdisk/disk718
Mode: C
VG: /dev/vg_data
Multipath Policy: A/A
Multipath Provider: Native
host vserver /dev/dsk HP A/A
path path filename host vserver path failover
state type or hardware path adapter LIF priority
up primary /dev/dsk/c37t6d7 fclp0 hpux_7 0
up primary /dev/dsk/c22t6d7 fclp1 hpux_8 0
up secondary /dev/dsk/c36t6d7 fclp0 hpux_5 1
up secondary /dev/dsk/c44t6d7 fclp1 hpux_6 1
列出从给定 SVM 映射到主机的所有 LUN
检索从特定 SVM 映射到主机的所有 LUN 的列表。
sanlun lun show -p -v vs_hp_cluster
显示示例输出
LUN: 55
LUN Size: 15g
Mode: C
VG: /dev/vg_data
列出映射到主机的给定 LUN 的所有属性
检索映射到主机的指定 LUN 的所有属性的列表。
sanlun lun show -p -v vs_hp_cluster:/vol/chathpux_217_vol_en_1_5/hp_en_217_lun
显示示例输出
ONTAP Path: vs_hp_cluster:/vol/chathpux_217_vol_en_1_5/hp_en_217_lun
LUN: 49
LUN Size: 15g
Host Device: /dev/rdisk/disk712
Mode: C
VG: /dev/vg_data
up primary /dev/dsk/c37t6d1 fclp0 hpux_7 0
up primary /dev/dsk/c22t6d1 fclp1 hpux_8 0
up secondary /dev/dsk/c36t6d1 fclp0 hpux_5 1
up secondary /dev/dsk/c44t6d1 fclp1 hpux_6 1
按主机设备文件名列出ONTAP LUN属性
通过指定的主机设备文件名检索ONTAP LUN 属性列表。
sanlun lun show -dv /dev/rdisk/disk716
显示示例输出
device host lun
vserver lun-pathname filename adapter protocol size mode
vs_hp_cluster /vol/chathpux_217_vol_en_1_14/hp_en_217_lun /dev/rdisk/disk716 0 FCP 15g C
LUN Serial number: 80D7l?NiNP5U
Controller Model Name: AFF-A800
Vserver FCP nodename: 208400a098ba7afe
Vserver FCP portname: 207e00a098ba7afe
Vserver LIF name: hpux_5
Vserver IP address: 10.141.54.30
10.141.54.35
10.141.54.37
10.141.54.33
10.141.54.31
Vserver volume name: chathpux_217_vol_en_1_14 MSID::0x00000000000000000000000080915935
Vserver snapshot name:
列出连接到主机的所有 SVM 目标 LIF WWPN
检索连接到主机的所有 SVM 目标 LIF WWPN 的列表。
sanlun lun show -wwpn
显示示例输出
controller(7mode)/ vserver(Cmode) target wwpn lun-pathname device filename -------------------------------------------------------------------------------------------------------- vs_hp_cluster 208300a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c22t6d7 vs_hp_cluster 208100a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c44t6d7 vs_hp_cluster 208200a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c37t6d7 vs_hp_cluster 207e00a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c36t6d7 vs_hp_cluster 207d00a098ba7afe /vol/chathpux_217_os/hp_217_os /dev/rdsk/c18t7d4 vs_hp_cluster 207f00a098ba7afe /vol/chathpux_217_os/hp_217_os /dev/rdsk/c42t7d4 host adapter lun size mode --------------------------------- fclp1 15g C fclp1 15g C fclp0 15g C fclp0 15g C fclp1 30g C fclp0 30g C
