Solaris Host Utilities 6.2命令参考
贡献者
建议更改
您可以使用Solaris Host Utilities 6.2示例命令参考来使用Host Utilities工具对NetApp存储配置进行端到端验证。
列出映射到主机的所有主机启动程序
您可以检索映射到主机的所有主机启动程序的列表。
# sanlun fcp show adapter -v
示例输出
adapter name: qlc3 WWPN: 21000024ff17a301 WWNN: 20000024ff17a301 driver name: qlc model: 7335902 model description: 7115462, Oracle Storage Dual-Port 32 Gb Fibre Channel PCIe HBA serial number: 463916R+1720333838 hardware version: Not Available driver version: 210226-5.10 firmware version: 8.08.04 Number of ports: 1 of 2 port type: Fabric port state: Operational supported speed: 8 GBit/sec, 16 GBit/sec, 32 GBit/sec negotiated speed: 32 GBit/sec OS device name: /dev/cfg/c7 adapter name: qlc2 WWPN: 21000024ff17a300 WWNN: 20000024ff17a300 driver name: qlc model: 7335902 model description: 7115462, Oracle Storage Dual-Port 32 Gb Fibre Channel PCIe HBA serial number: 463916R+1720333838 hardware version: Not Available driver version: 210226-5.10 firmware version: 8.08.04 Number of ports: 2 of 2 port type: Fabric port state: Operational supported speed: 8 GBit/sec, 16 GBit/sec, 32 GBit/sec negotiated speed: 16 GBit/sec OS device name: /dev/cfg/c6
列出映射到主机的所有 LUN
您可以检索映射到主机的所有LUN的列表。
# sanlun lun show -p -v all
示例输出
ONTAP Path: data_vserver:/vol1/lun1 LUN: 1 LUN Size: 10g Host Device: /dev/rdsk/c0t600A0980383044485A3F4E694E4F775Ad0s2 Mode: C Multipath Provider: Sun Microsystems Multipath Policy: Native
列出从给定 SVM/ 映射到主机的所有 LUN 列出映射到主机的给定 LUN 的所有属性
您可以从特定SVM检索映射到主机的所有LUN的列表。
# sanlun lun show -p -v sanboot_unix`
示例输出
ONTAP Path: sanboot_unix:/vol/sol_boot/sanboot_lun LUN: 0 LUN Size: 180.0g
按主机设备文件名列出ONTAP LUN属性
您可以通过指定主机设备文件名来检索所有ONTAP LUN属性的列表。
# sanlun lun show all
示例输出
controller(7mode/E-Series)/ device vserver(cDOT/FlashRay) lun-pathname filename --------------------------------------------------------------------------------------------------------------- sanboot_unix /vol/sol_193_boot/chatsol_193_sanboot /dev/rdsk/c0t600A098038304437522B4E694E4A3043d0s2 host adapter protocol lun size product --------------------------------------------- qlc3 FCP 180.0g cDOT
