VSS请求程序—备份组件失败、并出现部分写入程序错误
* 消息 *
Error: Vss Requestor - Backup Components failed with partial writer error. Writer Microsoft Hyper-V VSS Writer involved in backup or restore operation reported partial failure. Writer returned failure code 0x80042336. Writer state is 5. Application specific error information: Application error code: 0x1 Application error message: - Failed component information: Failed component: VM GUID XXX Writer error code: 0x800423f3 Application error code: 0x8004230f Application error message: Failed to revert to VSS snapshot on the virtual hard disk 'volume_guid' of the virtual machine 'vm_name'. (Virtual machine ID XXX)Hyper-V主机上的Windows应用程序事件日志中显示以下错误:
Volume Shadow Copy Service error: Unexpected error calling routine GetOverlappedResult. hr = 0x80070057, The parameter is incorrect. Operation: Revert a Shadow Copy Context: Execution Context: System Provider Volume Shadow Copy Service error: Error calling a routine on a Shadow Copy Provider {b5946137-7b9f-4925-af80-51abd60b20d5}. Routine details RevertToSnapshot [hr = 0x80042302, A Volume Shadow Copy Service component encountered an unexpected error. Check the Application event log for more information.]. Operation: Revert a Shadow Copy Context: Execution Context: Coordinator -
* 问题描述 *
对数据集执行应用程序一致的备份时、会显示此消息。此错误会导致数据集中某些虚拟机的备份失败。
* 更正操作 *
重试数据集备份。
如果重试尝试再次失败、请将数据集拆分为两个数据集、以便将备份失败的所有VM放置在一个数据集中、而所有其他VM将放置在另一个数据集中。然后再次运行备份。
