NetApp data management solutions
從 7-模式到ONTAP 的資料遷移
貢獻者 kevin-hoke
本節提供將資料從以 7 模式運行的NetApp Data ONTAP遷移到ONTAP的詳細步驟。
將 7 模式 NFSv3 儲存過渡到ONTAP以用於 NFS 數據
本節提供了下表中將來源 7-模式 NFSv3 導出過渡到ONTAP系統的逐步過程。
NetApp假定來源 7-模式 NFSv3 磁碟區已匯出並安裝在用戶端系統上,且 XCP 已安裝在 Linux 系統上。
  1. 驗證目標ONTAP系統是否正常。
    CLUSTER::> cluster show
    Node                  Health  Eligibility
    CLUSTER-01            true    true
    CLUSTER-02            true    true
    2 entries were displayed.
    CLUSTER::> node show
    Node      Health Eligibility Uptime        Model       Owner    Location
    CLUSTER-01
              true   true        78 days 21:01 FAS8060              RTP
    CLUSTER-02
              true   true        78 days 20:50 FAS8060              RTP
    CLUSTER::> storage failover show
                                  Takeover
    Node           Partner        Possible State Description
    CLUSTER-01     CLUSTER-02     true     Connected to CLUSTER-02
    CLUSTER-02     CLUSTER-01     true     Connected to CLUSTER-01
  2. 驗證目標系統上是否存在至少一個非根聚合。總量正常。
    CLUSTER::> storage aggregate show
    Aggregate     Size Available Used% State   #Vols  Nodes            RAID Status
    aggr0      368.4GB   17.85GB   95% online       1 CLUSTER-01       raid_dp,
        normal
    aggr0_CLUSTER_02_0
               368.4GB   17.85GB   95% online       1 CLUSTER-02       raid_dp,
        normal
    source      1.23TB    1.10TB   11% online       6 CLUSTER-01       raid_dp,
        normal
    3 entries were displayed.
    如果沒有資料聚合,請使用 `storage aggr create`命令。
  3. 在目標叢集系統上建立儲存虛擬機器 (SVM)。
    CLUSTER::> vserver create -vserver dest -rootvolume dest_root -aggregate poc -rootvolume-security-style mixed
    [Job 647] Job succeeded:
    Vserver creation completed
    Verify the security style and language settings of the source
    Verify that the SVM was successfully created.
    CLUSTER::> vserver show -vserver dest
                                        Vserver: dest
                                   Vserver Type: data
                                Vserver Subtype: default
                                   Vserver UUID: 91f6d786-0063-11e5-b114-00a09853a969
                                    Root Volume: dest_root
                                      Aggregate: poc
                                     NIS Domain: -
                     Root Volume Security Style: mixed
                                    LDAP Client: -
                   Default Volume Language Code: C.UTF-8
                                Snapshot Policy: default
                                        Comment:
                                   Quota Policy: default
                    List of Aggregates Assigned: -
     Limit on Maximum Number of Volumes allowed: unlimited
                            Vserver Admin State: running
                      Vserver Operational State: running
       Vserver Operational State Stopped Reason: -
                              Allowed Protocols: nfs, cifs, fcp, iscsi, ndmp
                           Disallowed Protocols: -
                Is Vserver with Infinite Volume: false
                               QoS Policy Group: -
                                    Config Lock: false
                                   IPspace Name: Default
  4. 從目標 SVM 中刪除 FCP、iSCSI、NDMP 和 CIDS 協定。
    CLUSTER::> vserver remove-protocols -vserver dest -protocols fcp,iscsi,ndmp,cifs
    驗證 NFS 是否是此 SVM 允許的協定。
    CLUSTER::> vserver show -vserver dest -fields allowed-protocols
    vserver allowed-protocols
    dest    nfs
  5. 在目標 SVM 上建立新的讀寫資料磁碟區。驗證安全模式、語言設定和容量要求是否與來源磁碟區相符。
    CLUSTER::> vol create -vserver dest -volume dest_nfs -aggregate poc -size 150g -type RW -state online -security-style mixed
    [Job 648] Job succeeded: Successful
  6. 建立資料 LIF 來滿足 NFS 客戶端請求。
    CLUSTER::> network interface create -vserver dest -lif dest_lif -address 10.61.73.115 -netmask 255.255.255.0 -role data -data-protocol nfs -home-node CLUSTER-01 -home-port e0l
    驗證 LIF 是否已成功建立。
    CLUSTER::> network interface show -vserver dest
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    dest
                dest_lif
                             up/up    10.61.73.113/24    CLUSTER-01    e0i     true
  7. 如果需要,請使用 SVM 建立靜態路由。
    CLUSTER::> network route create -vserver dest -destination 0.0.0.0/0 -gateway 192.168.100.111
    驗證路線是否已成功建立。
    CLUSTER::> network route show -vserver source
    Vserver             Destination     Gateway         Metric
    dest
                        0.0.0.0/0       10.61.73.1      20
  8. 在 SVM 命名空間中掛載目標 NFS 資料磁碟區。
    CLUSTER::> volume mount -vserver dest -volume dest_nfs -junction-path /dest_nfs -active true
    驗證磁碟區是否已成功安裝。
    CLUSTER::> volume show -vserver dest -fields junction-path
    vserver volume   junction-path
    dest    dest_nfs /dest_nfs
    dest    dest_root
    您也可以使用下列指令指定磁碟區安裝選項(連線路徑) `volume create`命令。
  9. 在目標 SVM 上啟動 NFS 服務。
    CLUSTER::> vserver nfs start -vserver dest
    驗證服務是否已啟動並正在運行。
    CLUSTER::> vserver nfs status
    The NFS server is running on Vserver "dest".
    CLUSTER::> nfs show
    Vserver: dest
            General Access:  true
                        v3:  enabled
                      v4.0:  disabled
                       4.1:  disabled
                       UDP:  enabled
                       TCP:  enabled
      Default Windows User:  -
     Default Windows Group:  -
  10. 驗證預設 NFS 匯出策略是否已套用至目標 SVM。
    CLUSTER::> vserver export-policy show -vserver dest
    Vserver          Policy Name
    dest             default
  11. 如果需要,請為目標 SVM 建立新的自訂匯出策略。
    CLUSTER::> vserver export-policy create -vserver dest -policyname xcpexportpolicy
    驗證新的自訂匯出策略是否已成功建立。
    Vserver          Policy Name
    dest             default
    dest             xcpexportpolicy
  12. 修改導出策略規則以允許 NFS 用戶端存取。
    CLUSTER::> export-policy rule modify -vserver dest -ruleindex 1 -policyname xcpexportpolicy -clientmatch 0.0.0.0/0 -rorule any -rwrule any -anon 0
    Verify the policy rules have modified
    CLUSTER::> export-policy rule show -instance
                                        Vserver: dest
                                    Policy Name: xcpexportpolicy
                                     Rule Index: 1
                                Access Protocol: nfs3
    Client Match Hostname, IP Address, Netgroup, or Domain: 0.0.0.0/0
                                 RO Access Rule: none
                                 RW Access Rule: none
    User ID To Which Anonymous Users Are Mapped: 65534
                       Superuser Security Types: none
                   Honor SetUID Bits in SETATTR: true
                      Allow Creation of Devices: true
  13. 驗證客戶端是否被允許存取該磁碟區。
    CLUSTER::> export-policy check-access -vserver dest -volume dest_nfs -client-ip 10.61.82.215 -authentication-method none -protocol nfs3 -access-type read-write
                                             Policy    Policy       Rule
    Path                          Policy     Owner     Owner Type  Index Access
    /                             xcpexportpolicy
                                             dest_root volume          1 read
    /dest_nfs                     xcpexportpolicy
                                             dest_nfs  volume          1 read-write
  14. 連接到 Linux NFS 伺服器。為 NFS 匯出磁碟區建立掛載點。
    [root@localhost /]# cd /mnt
    [root@localhost mnt]# mkdir dest
  15. 在此掛載點掛載目標 NFSv3 匯出磁碟區。
    註 NFSv3 磁碟區應該被匯出但不一定由 NFS 伺服器掛載。如果可以安裝,XCP Linux 主機用戶端就會安裝這些磁碟區。
    [root@localhost mnt]# mount -t nfs 10.61.73.115:/dest_nfs /mnt/dest
    驗證掛載點是否已成功建立。
    [root@ localhost /]# mount | grep nfs
    10.61.73.115:/dest_nfs on /mnt/dest type nfs (rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.61.82.215,mountvers=3,mountport=4046,mountproto=udp,local_lock=none,addr=10.61.73.115)
  16. 在 NFS 匯出的掛載點上建立測試檔案以啟用讀寫存取。
    [root@localhost dest]# touch test.txt
    Verify the file is created
    [root@localhost dest]# ls -l
    total 0
    -rw-r--r-- 1 root bin 0 Jun  2 03:16 test.txt
    註 讀寫測試完成後,從目標NFS掛載點刪除該檔案。
  17. 連接到安裝了 XCP 的 Linux 用戶端系統。瀏覽到 XCP 安裝路徑。
    [root@localhost ~]# cd /linux/
    [root@localhost linux]#
  18. 透過執行以下命令查詢來源 7-模式 NFSv3 匯出 `xcp show`XCP Linux 用戶端主機系統上的指令。
    [root@localhost]#./xcp show 10.61.82.215
    == NFS Exports ==
    Mounts  Errors  Server
          4       0  10.61.82.215
         Space    Files      Space    Files
          Free     Free       Used     Used Export
      23.7 GiB  778,134    356 KiB       96 10.61.82.215:/vol/nfsvol1
      17.5 GiB  622,463   1.46 GiB      117 10.61.82.215:/vol/nfsvol
       328 GiB    10.8M   2.86 GiB    7,904 10.61.82.215:/vol/vol0/home
    == Attributes of NFS Exports ==
    drwxr-xr-x --- root wheel 4KiB 4KiB 2d21h 10.61.82.215:/vol/nfsvol1
    drwxrwxrwx --t root wheel 4KiB 4KiB 9d22h 10.61.82.215:/vol/vol0/home
    drwxr-xr-x --- root wheel 4KiB 4KiB  4d0h 10.61.82.215:/vol/vol0
    3.89 KiB in (5.70 KiB/s), 7.96 KiB out (11.7 KiB/s), 0s.
  19. 掃描來源 NFSv3 匯出路徑並列印其檔案結構的統計資料。
    NetApp建議在 xcp 期間將來源 NFSv3 匯出置於唯讀模式 scan, copy , 和 `sync`營運.
    [root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol
    nfsvol
    nfsvol/n5000-uk9.5.2.1.N1.1.bin
    nfsvol/821_q_image.tgz
    nfsvol/822RC2_q_image.tgz
    nfsvol/NX5010_12_node_RCF_v1.3.txt
    nfsvol/n5000-uk9-kickstart.5.2.1.N1.1.bin
    nfsvol/NetApp_CN1610_1.1.0.5.stk
    nfsvol/glibc-common-2.7-2.x86_64.rpm
    nfsvol/glibc-2.7-2.x86_64.rpm
    nfsvol/rhel-server-5.6-x86_64-dvd.iso.filepart
    nfsvol/xcp
    nfsvol/xcp_source
    nfsvol/catalog
    23 scanned, 7.79 KiB in (5.52 KiB/s), 1.51 KiB out (1.07 KiB/s), 1s.
  20. 將來源 7-模式 NFSv3 匯出複製到目標ONTAP系統上的 NFSv3 匯出。
    [root@localhost /]# ./xcp copy 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs
     44 scanned, 39 copied, 264 MiB in (51.9 MiB/s), 262 MiB out (51.5 MiB/s), 5s
     44 scanned, 39 copied, 481 MiB in (43.3 MiB/s), 479 MiB out (43.4 MiB/s), 10s
     44 scanned, 40 copied, 748 MiB in (51.2 MiB/s), 747 MiB out (51.3 MiB/s), 16s
     44 scanned, 40 copied, 1.00 GiB in (55.9 MiB/s), 1.00 GiB out (55.9 MiB/s), 21s
     44 scanned, 40 copied, 1.21 GiB in (42.8 MiB/s), 1.21 GiB out (42.8 MiB/s), 26s
    Sending statistics...
    44 scanned, 43 copied, 1.46 GiB in (47.6 MiB/s), 1.45 GiB out (47.6 MiB/s), 31s.
  21. 複製完成後,驗證來源和目標 NFSv3 匯出是否具有相同的資料。運行 `xcp verify`命令。
    [root@localhost /]# ./xcp verify 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs
    44 scanned, 44 found, 28 compared, 27 same data, 2.41 GiB in (98.4 MiB/s), 6.25 MiB out (255 KiB/s), 26s
    44 scanned, 44 found, 30 compared, 29 same data, 2.88 GiB in (96.4 MiB/s), 7.46 MiB out (249 KiB/s), 31s
    44 scanned, 100% found (43 have data), 43 compared, 100% verified (data, attrs, mods), 2.90 GiB in (92.6 MiB/s), 7.53 MiB out (240 KiB/s), 32s.
    如果 `xcp verify`發現來源資料和目標資料之間存在差異,則錯誤 `no such file or directory`在摘要中進行了報告。要解決該問題,請運行 `xcp sync`命令將來源變更複製到目標。
  22. 在切換之前和切換期間,運行 `verify`再次。如果來源有新的或更新的數據,則執行增量更新。運行 `xcp sync`命令。
    For this operation, the previous copy index name or number is required.
    [root@localhost /]# ./xcp sync -id 3
    Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs1'}
    64 reviewed, 64 checked at source, 6 changes, 6 modifications, 51.7 KiB in (62.5 KiB/s), 22.7 KiB out (27.5 KiB/s), 0s.
    xcp: sync '3': Starting search pass for 1 modified directory...
    xcp: sync '3': Found 6 indexed files in the 1 changed directory
    xcp: sync '3': Rereading the 1 modified directory to find what's new...
    xcp: sync '3': Deep scanning the 1 directory that changed...
    11 scanned, 11 copied, 12.6KiB in (6.19KiBps), 9.50 KiB out (4.66KiBps), 2s.
  23. 若要恢復先前中斷的複製操作,請執行 `xcp resume`命令。
    [root@localhost /]# ./xcp resume -id 4
    Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs7'}
    xcp: resume '4': WARNING: Incomplete index.
    xcp: resume '4': Found 18 completed directories and 1 in progress
    106 reviewed, 24.2 KiB in (30.3 KiB/s), 7.23 KiB out (9.06 KiB/s), 0s.
    xcp: resume '4': Starting second pass for the in-progress directory...
    xcp: resume '4': Found 3 indexed directories and 0 indexed files in the 1 in-progress directory
    xcp: resume '4': In progress dirs: unindexed 1, indexed 0
    xcp: resume '4': Resuming the 1 in-progress directory...
     20 scanned, 7 copied, 205 MiB in (39.6 MiB/s), 205 MiB out (39.6 MiB/s), 5s
     20 scanned, 14 copied, 425 MiB in (42.1 MiB/s), 423 MiB out (41.8 MiB/s), 11s
     20 scanned, 14 copied, 540 MiB in (23.0 MiB/s), 538 MiB out (23.0 MiB/s), 16s
     20 scanned, 14 copied, 721 MiB in (35.6 MiB/s), 720 MiB out (35.6 MiB/s), 21s
     20 scanned, 15 copied, 835 MiB in (22.7 MiB/s), 833 MiB out (22.7 MiB/s), 26s
     20 scanned, 16 copied, 1007 MiB in (34.3 MiB/s), 1005 MiB out (34.3 MiB/s), 31s
     20 scanned, 17 copied, 1.15 GiB in (33.9 MiB/s), 1.15 GiB out (33.9 MiB/s), 36s
     20 scanned, 17 copied, 1.27 GiB in (25.5 MiB/s), 1.27 GiB out (25.5 MiB/s), 41s
     20 scanned, 17 copied, 1.45 GiB in (36.1 MiB/s), 1.45 GiB out (36.1 MiB/s), 46s
     20 scanned, 17 copied, 1.69 GiB in (48.7 MiB/s), 1.69 GiB out (48.7 MiB/s), 51s
    20 scanned, 20 copied, 21 indexed, 1.77 GiB in (33.5 MiB/s), 1.77 GiB out (33.4 MiB/s), 54s.
    後 `resume`完成複製文件,運行 `verify`再次確保來源儲存和目標儲存具有相同的資料。
  24. NFSv3 用戶端主機需要卸載從 7-模式儲存配置的來源 NFSv3 匯出,並從ONTAP掛載目標 NFSv3 匯出。切換需要中斷。
將 7-模式磁碟區 Snapshot 副本過渡到ONTAP
本節介紹將來源 7-模式磁碟區NetApp Snapshot 副本過渡到ONTAP的過程。
註 NetApp假定來源 7-模式磁碟區已匯出並安裝在用戶端系統上,且 XCP 已安裝在 Linux 系統上。 Snapshot 副本是磁碟區的某個時間點映像,用於記錄自上次 Snapshot 副本以來的增量變更。使用 `-snap`以 7 模式系統為來源的選項。
*警告:*保留基本 Snapshot 副本。基線複製完成後,請勿刪除基線 Snapshot 副本。進一步的同步操作需要基本 Snapshot 副本。
  1. 驗證目標ONTAP系統是否正常。
    CLUSTER-01
    CLUSTER-02
                                  Takeover
        normal
    aggr0_CLUSTER_02_0
        normal
        normal
  3. 在目標叢集系統上建立 SVM。
                                        Vserver: dest
                                   Vserver Type: data
                                      Aggregate: poc
                                     NIS Domain: -
                                    LDAP Client: -
                                        Comment:
                               QoS Policy Group: -
                                    Config Lock: false
  4. 從目標 SVM 中刪除 FCP、iSCSI、NDMP 和 CIFS 協定。
    Verify that NFS is the allowed protocol for this SVM.
    dest    nfs
    驗證 LIF 是否已成功建立。
    dest
                dest_lif
    驗證路線是否已成功建立。
    dest
    驗證磁碟區是否已成功安裝。
    dest    dest_root
    驗證服務是否已啟動並正在運行。
    CLUSTER::> nfs show
    Vserver: dest
                        v3:  enabled
                      v4.0:  disabled
                       4.1:  disabled
                       UDP:  enabled
                       TCP:  enabled
    Vserver          Policy Name
    dest             default
    驗證新的自訂匯出策略是否已成功建立。
    Vserver          Policy Name
    dest             default
  12. 修改導出策略規則以允許存取目標系統上的 NFS 用戶端。
                                        Vserver: dest
                                     Rule Index: 1
  13. 驗證客戶端是否可以存取目標磁碟區。
                                             Policy    Policy       Rule
    /                             xcpexportpolicy
    驗證掛載點是否已成功建立。
    total 0
    == NFS Exports ==
          4       0  10.61.82.215
    NetApp建議在以下情況下將來源 NFSv3 匯出置於唯讀模式: xcp scan , copy , 和 `sync`營運.在 `sync`操作時,您必須通過 `-snap`具有相應值的選項。
    [root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol/.snapshot/snap1
    nfsvol
    nfsvol/catalog
    [root@scspr1202780001 vol_acl4]# ./xcp  sync -id 7msnap1  -snap 10.236.66.199:/vol/nfsvol/.snapshot/snap10
    (show scan and sync)
  20. 將來源 7-模式 NFSv3 快照(基礎)複製到目標ONTAP系統上的 NFSv3 匯出。
    [root@localhost /]# /xcp copy 10.61.82.215:/vol/nfsvol/.snapshot/snap1
    註 保留此基本快照以進行進一步的同步操作。
    如果 `verify`發現來源資料和目標資料之間存在差異,則錯誤 `no such file or directory `is reported in the summary. To fix that issue, run the `xcp sync`命令將來源變更複製到目標。
  22. 在切換之前和切換期間,運行 `verify`再次。如果來源有新的或更新的數據,則執行增量更新。如果有增量更改,請為這些變更建立新的 Snapshot 副本,並將該快照路徑與 `-snap`同步操作的選項。
    運行 `xcp sync`命令 `-snap`選項和快照路徑。
    Index: {source: '10.61.82.215:/vol/nfsvol/.snapshot/snap1', target: '10.61.73.115:/dest_nfs1'}
    11 scanned, 11 copied, 12.6 KiB in (6.19 KiB/s), 9.50 KiB out (4.66 KiB/s), 2s..
    註 對於此操作,需要基礎快照。
    [root@scspr1202780001 534h_dest_vol]# ./xcp resume -id 3
    XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxxxx [NetApp Inc] until Mon Dec 31 00:00:00 2029
    xcp: Index: {source: '10.61.82.215:/vol/nfsvol',/.snapshot/snap1, target: 10.237.160.55:/dest_vol}
    xcp: resume '7msnap_res1': Reviewing the incomplete index...
    xcp: diff '7msnap_res1': Found 143 completed directories and 230 in progress
    39,688 reviewed, 1.28 MiB in (1.84 MiB/s), 13.3 KiB out (19.1 KiB/s), 0s.
    xcp: resume '7msnap_res1': Starting second pass for the in-progress directories...
    xcp: resume '7msnap_res1': Resuming the in-progress directories...
    xcp: resume '7msnap_res1': Resumed command: copy {-newid: u'7msnap_res1'}
    xcp: resume '7msnap_res1': Current options: {-id: '7msnap_res1'}
    xcp: resume '7msnap_res1': Merged options: {-id: '7msnap_res1', -newid: u'7msnap_res1'}
    xcp: resume '7msnap_res1': Values marked with a * include operations before resume
     68,848 scanned*, 54,651 copied*, 39,688 indexed*, 35.6 MiB in (7.04 MiB/s), 28.1 MiB out (5.57 MiB/s), 5s
  24. NFSv3 用戶端主機必須卸載從 7-模式儲存配置的來源 NFSv3 匯出,並從ONTAP掛載目標 NFSv3 匯出。此切換需要停機。
將 ACLv4 從NetApp 7-模式遷移到NetApp儲存系統
本節介紹將來源 NFSv4 導出過渡到ONTAP系統的逐步過程。
註 NetApp假定來源 NFSv4 磁碟區已匯出並安裝在用戶端系統上,且 XCP 已安裝在 Linux 系統上。來源應該是支援 ACL 的NetApp 7-模式系統。僅支援從NetApp到NetApp 的ACL 遷移。若要複製名稱中帶有特殊字元的文件,請確保原始檔案和目標檔案支援 UTF-8 編碼語言。
將來源 NFSv4 導出移轉到ONTAP 的前提條件
將來源 NFSv4 匯出移轉到ONTAP之前,必須滿足以下先決條件:
  • 目標系統必須配置 NFSv4。
  • NFSv4 來源和目標必須安裝在 XCP 主機上。選擇 NFS v4.0 來匹配來源和目標存儲,並驗證來源和目標系統上是否啟用了 ACL。
  • XCP 要求將來源/目標路徑掛載到 XCP 主機上以進行 ACL 處理。在下面的範例中, `vol1(10.63.5.56:/vol1)`安裝在 `/mnt/vol1`小路:
 [root@localhost ~]# df -h
Filesystem                                                   Size  Used Avail Use% Mounted on
10.63.5.56:/vol1                                             973M  4.2M  969M   1% /mnt/vol1
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/
XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029
drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1
rw-r--r-- --- root root    4    0 23h42m vol1/DIR1/FILE
drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11
rw-r--r-- --- root root    4    0 23h42m vol1/DIR1/DIR11/FILE
drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11/DIR2
rw-r--r-- --- root root    4    0 23h42m vol1/DIR1/DIR11/DIR2/FILE
drwxr-xr-x --- root root 4KiB 4KiB 17m43s vol1/DIR1/DIR11/DIR2/DIR22
8 scanned, 8 getacls, 1 v3perm, 7 acls, 3.80 KiB in (3.86 KiB/s), 1.21 KiB out (1.23 KiB/s), 0s.
子目錄選項
使用子目錄的兩個選項如下:
  • 為了讓 XCP 在子目錄上運作 (/vol1/DIR1/DIR11)、掛載完整路徑(10.63.5.56:/vol1/DIR1/DIR11) 在 XCP 主機上。
    如果沒有掛載完整路徑,XCP會回報以下錯誤:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/DIR1/DIR11
xcp: ERROR: For xcp to process ACLs, please mount 10.63.5.56:/vol1/DIR1/DIR11 using the OS nfs4 client.
  • 使用子目錄語法(mount: subdirectory/qtree/.snapshot),如下例所示:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1:/DIR1/DIR11
drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11
rw-r--r-- --- root root    4    0 23h51m DIR11/DIR2/FILE
drwxr-xr-x --- root root 4KiB 4KiB  26m9s DIR11/DIR2/DIR22
rw-r--r-- --- root root    4    0 23h51m DIR11/FILE
drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11/DIR2
5 scanned, 5 getacls, 5 acls, 2.04 KiB in (3.22 KiB/s), 540 out (850/s), 0s.
完成以下步驟將 ACLv4 從NetApp 7-模式移轉到NetApp儲存系統。
  1. 驗證目標ONTAP系統是否正常。
    CLUSTER-01
    CLUSTER-02
                                  Takeover
        normal
    aggr0_CLUSTER_02_0
        normal
        normal
  3. 在目標叢集系統上建立 SVM。
    驗證 SVM 是否已成功建立。
                                        Vserver: dest
                                   Vserver Type: data
                                      Aggregate: poc
                                     NIS Domain: -
                                    LDAP Client: -
                                        Comment:
                               QoS Policy Group: -
                                    Config Lock: false
    dest    nfs
    驗證 LIF 是否已成功建立。
    dest
                dest_lif
    驗證路線是否已成功建立。
    dest
    驗證磁碟區是否已成功安裝。
    dest    dest_root
    驗證服務是否已啟動並正在運行。
    CLUSTER::> nfs show
    Vserver: dest
                        v3:  enabled
                      v4.0:  enabled
                       4.1:  disabled
                       UDP:  enabled
                       TCP:  enabled
  10. 檢查預設 NFS 導出策略是否套用於目標 SVM。
    Vserver          Policy Name
    dest             default
    驗證新的自訂匯出策略是否已成功建立。
    Vserver          Policy Name
    dest             default
    驗證策略規則是否已修改。
                                        Vserver: dest
                                     Rule Index: 1
                                             Policy    Policy       Rule
    /                             xcpexportpolicy
  15. 在此掛載點掛載目標 NFSv4 匯出磁碟區。
    註 NFSv4 磁碟區應該被匯出但不一定由 NFS 伺服器掛載。如果可以安裝,XCP Linux 主機用戶端就會安裝這些磁碟區。
    [root@localhost mnt]# mount -t nfs4 10.63.5.56:/vol1 /mnt/vol1
    驗證掛載點是否已成功建立。
    [root@localhost mnt]# mount | grep nfs
    10.63.5.56:/vol1 on /mnt/vol1 type nfs4 (rw,relatime,vers=4.0,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,
    retrans=2,sec=sys,clientaddr=10.234.152.84,local_lock=none,addr=10.63.5.56)
    驗證文件是否已建立。
    total 0
  18. 透過執行以下命令查詢來源 NFSv4 匯出 `xcp show`XCP Linux 用戶端主機系統上的指令。
    root@localhost]# ./xcp show 10.63.5.56
    XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029
    getting pmap dump from 10.63.5.56 port 111...
    getting export list from 10.63.5.56...
    sending 6 mounts and 24 nfs requests to 10.63.5.56...
    == RPC Services ==
    '10.63.5.56': UDP rpc services: MNT v1/2/3, NFS v3, NLM v4, PMAP v2/3/4, STATUS v1
    '10.63.5.56': TCP rpc services: MNT v1/2/3, NFS v3/4, NLM v4, PMAP v2/3/4, STATUS v1
    == NFS Exports ==
          6       0  10.63.5.56
      94.7 MiB   19,883    324 KiB      107 10.63.5.56:/
       971 MiB   31,023   2.19 MiB       99 10.63.5.56:/vol2
       970 MiB   31,024   2.83 MiB       98 10.63.5.56:/vol1
      9.33 GiB  310,697    172 MiB      590 10.63.5.56:/vol_005
      43.3 GiB    1.10M   4.17 GiB    1.00M 10.63.5.56:/vol3
      36.4 GiB    1.10M   11.1 GiB    1.00M 10.63.5.56:/vol4
    drwxr-xr-x --- root root 4KiB 4KiB 6d2h 10.63.5.56:/
    drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol2
    drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol1
    drwxr-xr-x --- root root 4KiB 4KiB 9d2h 10.63.5.56:/vol_005
    drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol3
    drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol4
    6.09 KiB in (9.19 KiB/s), 12.2 KiB out (18.3 KiB/s), 0s.
  19. 掃描來源 NFSv4 匯出路徑並列印其檔案結構的統計資料。
    NetApp建議在以下情況下將來源 NFSv4 匯出置於唯讀模式: xcp scan , copy , 和 `sync`營運.
    [root@localhost]# ./xcp scan -acl4 10.63.5.56:/vol1
    vol1
    vol1/test/f1
    vol1/test
    3 scanned, 3 getacls, 3 v3perms, 1.59 KiB in (1.72 KiB/s), 696 out (753/s), 0s.
  20. 將來源 NFSv4 匯出複製到目標ONTAP系統上的 NFSv4 匯出。
    [root@localhost]# ./xcp copy -acl4 -newid id1 10.63.5.56:/vol1 10.63.5.56:/vol2
    3 scanned, 2 copied, 3 indexed, 3 getacls, 3 v3perms, 1 setacl, 14.7 KiB in (11.7 KiB/s), 61 KiB out (48.4 KiB/s), 1s..
  21. 後 `copy`完成後,驗證來源和目標 NFSv4 導出是否具有相同的資料。運行 `xcp verify`命令。
    [root@localhost]# ./xcp verify -acl4 -noid 10.63.5.56:/vol1 10.63.5.56:/vol2
    3 scanned, 100% found (0 have data), 100% verified (data, attrs, mods, acls), 6 getacls, 6 v3perms, 2.90 KiB in (4.16 KiB/s), 2.94 KiB out (4.22 KiB/s), 0s.
    如果 `verify`發現來源資料和目標資料之間存在差異,則錯誤 `no such file or directory`在摘要中進行了報告。要解決該問題,請運行 `xcp sync`命令將來源變更複製到目標。
    [root@ root@localhost]# ./xcp sync -id id1
    xcp: Index: {source: 10.63.5.56:/vol1, target: 10.63.5.56:/vol2}
    3 reviewed, 3 checked at source, no changes, 3 reindexed, 25.6 KiB in (32.3 KiB/s), 23.3 KiB out (29.5 KiB/s), 0s.
    註 對於此操作,需要先前的複製索引名稱或編號。
  23. 恢復先前中斷的 `copy`操作,運行 `xcp resume`命令。
    [root@localhost]# ./xcp resume -id id1
    xcp: Index: {source: 10.63.5.56:/vol3, target: 10.63.5.56:/vol4}
    xcp: resume 'id1': Reviewing the incomplete index...
    xcp: diff 'id1': Found 0 completed directories and 8 in progress
    39,899 reviewed, 1.64 MiB in (1.03 MiB/s), 14.6 KiB out (9.23 KiB/s), 1s.
    xcp: resume 'id1': Starting second pass for the in-progress directories...
    xcp: resume 'id1': Resuming the in-progress directories...
    xcp: resume 'id1': Resumed command: copy {-acl4: True}
    xcp: resume 'id1': Current options: {-id: 'id1'}
    xcp: resume 'id1': Merged options: {-acl4: True, -id: 'id1'}
    xcp: resume 'id1': Values marked with a * include operations before resume
     86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (2.60 MiB/s), 78.4 KiB out (15.6 KiB/s), 5s 86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (0/s), 78.4 KiB out (0/s), 10s
    1.00M scanned, 100% found (1M have data), 1M compared, 100% verified (data, attrs, mods, acls), 2.00M getacls, 202 v3perms, 1.00M same acls, 2.56 GiB in (2.76 MiB/s), 485 MiB out (524 KiB/s), 15m48s.
將 7-模式 SMB 儲存過渡到ONTAP以用於 CIFS 數據
本節介紹將來源 7-模式 SMB 共享過渡到ONTAP系統的逐步過程。
註 NetApp假定 7-模式和ONTAP系統是 SMB 許可的。已建立目標 SVM、匯出來源和目標 SMB 共用,並已安裝和授權 XCP。
  1. 掃描 SMB 共享中的檔案和目錄。
    C:\xcp>xcp scan -stats \\10.61.77.189\performance_SMB_home_dirs
    XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029
    == Maximum Values ==
    Size Depth Namelen Dirsize
    15.6MiB 2 8 200
    == Average Values ==
    540KiB 2 7 81
    == Top File Extensions ==
    .txt .tmp
    5601 2200
    == Number of files ==
    empty <8KiB 8-64KiB 64KiB-1MiB 1-10MiB 10-100MiB >100MiB
    46 6301 700 302 200 252
    == Space used ==
    0 6.80MiB 8.04MiB 120MiB 251MiB 3.64GiB 0
    == Directory entries ==
    empty 1-10 10-100 100-1K 1K-10K >10k
    18 1 77 1
    == Depth ==
    0-5 6-10 11-15 16-20 21-100 >100
    7898
    == Modified ==
    >1 year >1 month 1-31 days 1-24 hrs <1 hour <15 mins future
    2167 56 322 5353
    == Created ==
    2171 54 373 5300
    Total count: 7898
    Directories: 97
    Regular files: 7801
    Symbolic links:
    Junctions:
    Special files:
    Total space for regular files: 4.02GiB
    Total space for directories: 0
    Total space used: 4.02GiB
    7,898 scanned, 0 errors, 0s
  2. 將檔案(有或沒有 ACL)從來源複製到目標 SMB 共用。以下範例顯示了具有 ACL 的副本。
    C:\xcp>xcp copy -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs
    7,898 scanned, 0 errors, 0 skipped, 184 copied, 96.1MiB (19.2MiB/s), 5s
    7,898 scanned, 0 errors, 0 skipped, 333 copied, 519MiB (84.7MiB/s), 10s
    7,898 scanned, 0 errors, 0 skipped, 366 copied, 969MiB (89.9MiB/s), 15s
    7,898 scanned, 0 errors, 0 skipped, 422 copied, 1.43GiB (99.8MiB/s), 20s
    7,898 scanned, 0 errors, 0 skipped, 1,100 copied, 1.69GiB (52.9MiB/s), 25s
    7,898 scanned, 0 errors, 0 skipped, 1,834 copied, 1.94GiB (50.4MiB/s), 30s
    7,898 scanned, 0 errors, 0 skipped, 1,906 copied, 2.43GiB (100MiB/s), 35s
    7,898 scanned, 0 errors, 0 skipped, 2,937 copied, 2.61GiB (36.6MiB/s), 40s
    7,898 scanned, 0 errors, 0 skipped, 2,969 copied, 3.09GiB (100.0MiB/s), 45s
    7,898 scanned, 0 errors, 0 skipped, 3,001 copied, 3.58GiB (100.0MiB/s), 50s
    7,898 scanned, 0 errors, 0 skipped, 3,298 copied, 4.01GiB (88.0MiB/s), 55s
    7,898 scanned, 0 errors, 0 skipped, 5,614 copied, 4.01GiB (679KiB/s), 1m0s
    7,898 scanned, 0 errors, 0 skipped, 7,879 copied, 4.02GiB (445KiB/s), 1m5s
    7,898 scanned, 0 errors, 0 skipped, 7,897 copied, 4.02GiB (63.2MiB/s), 1m5s
    註 如果沒有資料聚合,則使用儲存空間建立新的資料聚合 `aggr create`命令。
  3. 同步來源和目標上的檔案。
    C:\xcp>xcp sync -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs
    10,796 scanned, 4,002 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 5s
    15,796 scanned, 8,038 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 10s
    15,796 scanned, 8,505 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 15s
    15,796 scanned, 8,707 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 20s
    15,796 scanned, 8,730 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 25s
    15,796 scanned, 8,749 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 30s
    15,796 scanned, 8,765 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 35s
    15,796 scanned, 8,786 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 40s
    15,796 scanned, 8,956 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 45s
    8 XCP v1.6 User Guide © 2020 NetApp, Inc. All rights reserved.
    Step Description
    15,796 scanned, 9,320 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 50s
    15,796 scanned, 9,339 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 55s
    15,796 scanned, 9,363 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m0s
    15,796 scanned, 10,019 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m5s
    15,796 scanned, 10,042 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m10s
    15,796 scanned, 10,059 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m15s
    15,796 scanned, 10,075 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m20s
    15,796 scanned, 10,091 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m25s
    15,796 scanned, 10,108 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m30s
    15,796 scanned, 10,929 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m35s
    15,796 scanned, 12,443 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m40s
    15,796 scanned, 13,963 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m45s
    15,796 scanned, 15,488 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m50s
    15,796 scanned, 15,796 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m51s
  4. 驗證文件是否被正確複製。
    C:\xcp> xcp verify \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dir
    8 compared, 8 same, 0 different, 0 missing, 5s
    24 compared, 24 same, 0 different, 0 missing, 10s
    41 compared, 41 same, 0 different, 0 missing, 15s
    63 compared, 63 same, 0 different, 0 missing, 20s
    86 compared, 86 same, 0 different, 0 missing, 25s
    423 compared, 423 same, 0 different, 0 missing, 30s
    691 compared, 691 same, 0 different, 0 missing, 35s
    1,226 compared, 1,226 same, 0 different, 0 missing, 40s
    1,524 compared, 1,524 same, 0 different, 0 missing, 45s
    1,547 compared, 1,547 same, 0 different, 0 missing, 50s
    1,564 compared, 1,564 same, 0 different, 0 missing, 55s
    2,026 compared, 2,026 same, 0 different, 0 missing, 1m0s
    2,045 compared, 2,045 same, 0 different, 0 missing, 1m5s
    2,061 compared, 2,061 same, 0 different, 0 missing, 1m10s
    2,081 compared, 2,081 same, 0 different, 0 missing, 1m15s
    2,098 compared, 2,098 same, 0 different, 0 missing, 1m20s
    2,116 compared, 2,116 same, 0 different, 0 missing, 1m25s
    3,232 compared, 3,232 same, 0 different, 0 missing, 1m30s
    4,817 compared, 4,817 same, 0 different, 0 missing, 1m35s
    6,267 compared, 6,267 same, 0 different, 0 missing, 1m40s
    7,844 compared, 7,844 same, 0 different, 0 missing, 1m45s
    7,898 compared, 7,898 same, 0 different, 0 missing, 1m45s,cifs
