指令碼範例
貢獻者
這是使用結束狀態值的指令碼範例。
下列指令碼使用SnapDrive 適用於UNIX的程式碼結束狀態值:
#!/bin/sh # This script demonstrates a SnapDrive # script that uses exit codes. RET=0; #The above statement initializes RET and sets it to 0 snapdrive snap create -dg vg22 -snapname vg22_snap1; # The above statement executes the snapdrive command RET=$?; #The above statement captures the return code. #If the operation worked, print #success message. If the operation failed, print #failure message and exit. if [ $RET -eq 0 ]; then echo "snapshot created successfully" else echo "snapshot creation failed, snapdrive exit code was $RET" exit 1 fi exit 0;
如果REET=0、命令會成功執行、指令碼會輸出下列項目:
# ./tst_script snap create: snapshot vg22_snap1 contains: disk group vg22 containing host volumes lvol1 snap create: created snapshot betty:/vol/vol2:vg22_snap1 snapshot created successfully
如果RET =非零值、則命令未成功執行。以下範例顯示一般輸出:
# ./tst_script 0001-185 Command error: snapshot betty:/vol/vol2:vg22_snap1 already exists on betty:/vol/vol2. Please use -f (force) flag to overwrite existing snapshot snapshot creation failed, snapdrive exit code was 4
