Supported configurations in Azure
Contributors netapp-bcammett
Cloud Volumes ONTAP is available in Azure in two pricing options: pay-as-you-go and Bring Your Own License (BYOL). For pay-as-you-go, you can choose from three configurations: Explore, Standard, or Premium.
Supported configurations by license
Cloud Volumes ONTAP is available in Azure as a single node system and as a high-availability (HA) pair of nodes for fault tolerance and nondisruptive operations.
Upgrading a single node system to an HA pair is not supported. If you want to switch between a single node system and an HA pair, then you need to deploy a new system and replicate data from the existing system to the new system.
Single node systems
You can choose from the following configurations when deploying Cloud Volumes ONTAP as a single-node system in Azure:
Explore Standard Premium BYOL
Supported virtual machine types
DS3_v2
  • DS4_v2
  • DS13_v2
  • DS5_v2
  • DS14_v2
  • DS15_v2
  • DS3_v2
  • DS4_v2
  • DS5_v2
  • DS13_v2
  • DS14_v2
  • DS15_v2
Supported disk types 1
Standard HDD Managed Disks, Standard SSD Managed Disks, and Premium SSD Managed Disks
Cold data tiering to Blob storage
Not supported
Supported
Maximum system capacity
(disks + object storage)
2 TiB
10 TiB
368 TiB
368 TiB per license
Notes:
  1. Enhanced write performance is enabled when using SSDs, but not when using the DS3_v2 virtual machine type.
  2. For Azure region support, see Cloud Volumes Global Regions.
HA pairs
You can choose from the following configurations when deploying Cloud Volumes ONTAP as an HA pair in Azure:
Not supported
  • DS4_v2
  • DS13_v2
  • DS5_v2
  • DS14_v2
  • DS15_v2
  • DS4_v2
  • DS5_v2
  • DS13_v2
  • DS14_v2
  • DS15_v2
Not supported
Premium page blobs
Cold data tiering to Blob storage 2
Not supported
Supported
Not supported
10 TiB
368 TiB
368 TiB per license
Notes:
  1. For Azure region support, see Cloud Volumes Global Regions.
Supported disk sizes
In Azure, an aggregate can contain up to 12 disks that are all the same type and size.
Single node systems
Single node systems use Azure Managed Disks. The following disk sizes are supported:
Premium SSD Standard SSD Standard HDD
  • 500 GiB
  • 1 TiB
  • 2 TiB
  • 4 TiB
  • 8 TiB
  • 16 TiB
  • 32 TiB
  • 100 GiB
  • 500 GiB
  • 1 TiB
  • 2 TiB
  • 4 TiB
  • 8 TiB
  • 16 TiB
  • 32 TiB
  • 100 GiB
  • 500 GiB
  • 1 TiB
  • 2 TiB
  • 4 TiB
  • 8 TiB
  • 16 TiB
  • 32 TiB
HA pairs
HA pairs use Premium page blobs. The following disk sizes are supported:
  • 500 GiB
  • 1 TiB
  • 2 TiB
  • 4 TiB
  • 8 TiB
