Supported configurations in Azure
Several Cloud Volumes ONTAP configurations are supported in Azure.
Supported configurations by license
Cloud Volumes ONTAP is available in Azure as a single node system and as a high-availability (HA) pair of nodes for fault tolerance and nondisruptive operations.
Upgrading a single node system to an HA pair is not supported. If you want to switch between a single node system and an HA pair, then you need to deploy a new system and replicate data from the existing system to the new system.
Cloud Volumes ONTAP can run on either a Reserved or On-demand VM instance from your cloud provider. Solutions that use other VM instance types aren't supported.
Single node systems
You can choose from the following capacity-based or node-based licensing configurations when deploying Cloud Volumes ONTAP as a single-node system in Azure.
| Freemium | Optimized | Capacity-based license (Essentials and Professional) | |
Maximum system capacity |
500 GiB |
2 PiB |
2 PiB |
Supported virtual machine types |
Supported disk types 4 |
Standard HDD Managed Disks, Standard SSD Managed Disks, Premium SSD Managed Disks, and Premium SSD v2 Managed Disks. |
Notes:
1 The DS_v2 and Es_v3 machine families are no longer available for selection on BlueXP when deploying new instances of Cloud Volumes ONTAP in Azure. These families will be retained and supported only in older, existing systems. New deployments of Cloud Volumes ONTAP are supported in Azure only from the 9.12.1 release. We recommend that you switch to either Es_v4 or any other series compatible with Cloud Volumes ONTAP 9.12.1 and later. The DS_v2 and Es_v3 series machines, however, will be available for new deployments made through the API.
2 This VM type includes local NVMe storage, which Cloud Volumes ONTAP uses as Flash Cache. Flash Cache speeds access to data through real-time intelligent caching of recently read user data and NetApp metadata. It is effective for random read-intensive workloads, including databases, email, and file services. Learn more.
The minimum ONTAP version required for configuring Flash Cache on Azure is 9.13.1 GA.
3 These VM types use an Ultra SSD for VNVRAM, which provides better write performance.
If you choose any of these VM types when you deploy a new Cloud Volumes ONTAP system, you can't change to another VM type that doesn't use an Ultra SSD for VNVRAM. For example, you can't change from E8ds_v4 to E8s_v3, but you can change from E8ds_v4 to E32ds_v4 because both of those VM types use Ultra SSDs.
Similarly, when you deploy a new Cloud Volumes ONTAP system, you can't change the VM type to one that doesn't support Premium SSD v2 Managed Disks. To learn more about the supported configurations for Premium SSD v2 Managed Disks, refer to HA single availability zone configuration with shared managed disks.Conversely, if you deployed Cloud Volumes ONTAP using any other VM type, you won't be able to change to a VM type that uses an Ultra SSD for VNVRAM. For example, you can't change from E8s_v3 to E8ds_v4.
4 High write speed is supported with all instance types when using a single node system. You can enable high write speed from BlueXP during deployment or any time after. Learn more about choosing a write speed. Enhanced write performance is enabled when using SSDs.
| PAYGO Explore | PAYGO Standard | PAYGO Premium | Node-based BYOL | |
2 TiB 5 |
10 TiB |
368 TiB |
368 TiB per license |
Standard HDD Managed Disks, Standard SSD Managed Disks, and Premium SSD Managed Disks |
Notes:
5Data tiering to Azure Blob storage isn't supported with PAYGO Explore.
HA pairs
You can choose from the following configurations when deploying Cloud Volumes ONTAP as an HA pair in Azure.
HA pairs with page blob
You can use the following configurations with the existing Cloud Volumes ONTAP HA page blob deployments in Azure.
Azure page blobs are not supported for any new deployment. |
500 GiB |
2 PiB |
2 PiB |
Supported disk types |
Page blobs |
Notes:
Cloud Volumes ONTAP supports high write speed with these VM types when using an HA pair. You can enable high write speed from BlueXP during deployment or any time after. Learn more about choosing a write speed.
This VM is recommended only when Azure maintenance control is needed. It's not recommended for any other use case due to the higher pricing.
These VMs are only supported in deployments of Cloud Volumes ONTAP 9.11.1 or earlier. With these VM types you can upgrade an existing page blob deployment from Cloud Volumes ONTAP 9.11.1 to 9.12.1. You cannot perform new page blob deployments with Cloud Volumes ONTAP 9.12.1 or above.
Maximum system capacity (disks + object storage) |
10 TiB |
368 TiB |
Page blobs |
Notes:
HA pairs with shared managed disks
500 GiB |
2 PiB |
2 PiB |
Notes:
Multiple availability zone support starts from ONTAP version 9.13.1.
Multiple availability zone support starts from ONTAP version 9.14.1 RC1.
10 TiB |
368 TiB |
Managed disks |
Notes:
These VM types are only supported for HA pairs in a single availability zone configuration running on shared managed disks.
These VM types are supported for HA pairs in single availability zone and multiple availability zone configurations running on shared managed disks. For Ls_v3 VM types, multiple availability zone support starts from ONTAP version 9.13.1. For Eds_v5 VM types, multiple availability zone support starts from ONTAP version 9.14.1 RC1.
Supported disk sizes
In Azure, an aggregate can contain up to 12 disks that are all the same type and size.
Single node systems
Single node systems use Azure Managed Disks. The following disk sizes are supported:
| Premium SSD | Standard SSD | Standard HDD |
HA pairs
HA pairs use Azure Managed Disks. The following disk type and sizes are supported.
(Page blobs are supported with HA pairs deployed before the 9.12.1 release.)
Premium SSD
500 GiB
1 TiB
2 TiB
4 TiB
8 TiB
16 TiB (managed disks only)
32 TiB (managed disks only)
Supported regions
For Azure region support, see Cloud Volumes Global Regions.
