Manage ethernet ports with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (avaiable in ONTAP 9.7 and earlier) to create and manage Ethernet ports.
Create interface groups
You can use System Manager to create an interface group—​single-mode, static multimode, or dynamic multimode (LACP)--to present a single interface to clients by combining the capabilities of the aggregated network ports.
Before you begin
Free ports must be available that do not belong to any broadcast domain or interface group, or that host a VLAN.
Steps
  1. Click Network > Ethernet Ports.
  2. Click Create Interface Group.
  3. In the Create Interface Group dialog box, specify the following settings:
    • Name of the interface group
    • Node
    • Ports that you want to include in the interface group
    • Usage mode of the ports: single-mode, static multiple, or dynamic multimode (LACP)
    • Network load distribution: IP-based, MAC address-based, sequential, or port
    • Broadcast domain for the interface group, if required
  4. Click Create.
Create VLAN interfaces
You can create a VLAN to maintain separate broadcast domains within the same network domain by using System Manager.
Steps
  2. Click Create VLAN.
  3. In the Create VLAN dialog box, select the node, the physical interface, and the broadcast domain (if required).
    The physical interface list includes only Ethernet ports and interface groups. The list does not display interfaces that are in another interface group or an existing VLAN.
  4. Type a VLAN tag, and then click Add.
    You must add unique VLAN tags.
  5. Click Create.
Edit Ethernet port settings
You can edit Ethernet port settings such as the duplex mode and speed settings by using System Manager.
Steps
  2. Select the physical port, and then click Edit.
  3. In the Edit Ethernet Port dialog box, modify the duplex mode and speed settings to either manual or automatic.
  4. Click Edit.
Edit interface group settings
You can use System Manager to add ports to an interface group, to remove ports from an interface group, and to modify the usage mode and load distribution pattern of the ports in an interface group.
About this task
You cannot modify the MTU settings of an interface group that is assigned to a broadcast domain.
Steps
  2. Select an interface group, and then click Edit.
  3. Modify the interface group settings as required, and then click Save and Close.
Modify the MTU size of a VLAN
If you want to modify the MTU size of a VLAN interface that is not part of a broadcast domain, you can use System Manager to change the size.
About this task
You must not modify the MTU size of the management port e0M.
Steps
  2. Select the VLAN that you want to modify, and then click Edit.
  3. In the Edit VLAN dialog box, modify the MTU size as required, and then click Save.
Delete VLANs
You can delete VLANs that are configured on network ports by using System Manager. You might have to delete a VLAN before removing a NIC from its slot. When you delete a VLAN, the VLAN is automatically removed from all of the failover rules and groups that use the VLAN.
Before you begin
No LIFs must be associated with the VLAN.
Steps
  2. Select the VLAN that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Delete.
Ports and adapters
Ports are grouped under nodes and the nodes are displayed based on the selected protocol category. For example, if the data is served using the FC protocol, then only the nodes with FCP adapters are displayed. The hosted interface count helps you in choosing a port which is less loaded.
Related information
