Application provisioning settings in System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You must provide details when setting up a basic or enhanced template for a database, server, or virtual desktop in ONTAP System Manager classic (available in ONTAP 9.7 and earlier). After an application is provisioned, you can edit the details and specify a resizing (increased size only). This section describes the fields in each template. Only the fields that are required for provisioning or editing the settings of the specific application are displayed.
Details for Microsoft SQL Database Applications over SAN
You enter the following information to provision Microsoft SQL Database applications over SAN or edit the settings:
  • Database Name
    Mandatory: The name of the database you are configuring; this string is used as a prefix when provisioning storage for each database.
  • Database Size
    Mandatory: The size of the database, in units of MB, GB, TB, or PB.
  • ONTAP Service Level for Database
    Mandatory: The service level for the database.
  • Log Size
    Mandatory: The size of the database log in units of MB, GB, TB, or PB.
  • ONTAP Service Level for Log
    Mandatory: The service level for the log.
  • Tempdb
    Mandatory: The size of the tempdb database in units of MB, GB, TB, or PB.
  • Export Protocol
    Mandatory: The export protocol is SAN
  • Number of Server Cores (on the SQL server)
    Indicates the number of CPU cores on the databases server in increments of 2.
  • Span HA Controller Nodes
    Specifies if storage objects should be created across a high-availability pair of nodes.
Details for provisioning a SAP HANA database
  • Active SAP HANA Nodes
    The number of active SAP HANA nodes. The maximum number of nodes is 16.
  • Memory Size per HANA Node
    The memory size of a single SAP HANA node.
  • Data Disk Size per HANA Node
    The data disk size for each node.
    Note
    If set to 0, the memory size field above is used to calculate the size of the data area.
Details for Microsoft SQL Database Applications over SMB
You enter the following information to provision Microsoft SQL Database applications over SMB or edit the settings:
  • Database Name
  • Database Size
  • Database Service Level
  • Log Size
  • Log Service Level
  • Provision for Tempdb
    Mandatory: Indicates whether tempdb is provisioned.
  • Export Protocol
    Mandatory: The export protocol is SMB or SAN.
    SMB can be chosen only when the cluster is licensed for CIFS, which has been configured for the SVM.
  • Grant Access to User
    Mandatory: The access level for the application.
  • Permission
    Mandatory: The permission level for the application.
Details for a SQL Server Account
You enter the following information to provide full control access to the SQL server accounts:
Note
The installation account is granted SeSecurityPrivilege.
  • SQL Server Service Account
    Mandatory: This is an existing domain account; specify as domain\user.
  • SQL Server Agent Service Account
    Optional: This is this domain account if SQL server agent service is configured, specify in the format domain\user.
Details for Oracle Database Applications
You enter the following information to provision Oracle database applications or edit the settings:
  • Database Name
  • Datafile Size
    Mandatory: The size of the datafile, in units of MB, GB, TB, or PB.
  • ONTAP Service Level for Datafile
    Mandatory: The service level for the datafile.
  • Redo Log Group Size
    Mandatory: The size of the redo log group, in units of MB, GB, TB, or PB.
  • ONTAP Service Level for Redo Log Group
    Mandatory: The service level for the redo log group.
  • Archive Log Size
    Mandatory: The size of the archive log, in units of MB, GB, TB, or PB.
  • ONTAP Service Level for the Archive Log
    Mandatory: The service level for the archive group.
  • Export Protocol
    The export protocol: SAN or NFS
  • Initiators
    A comma-separated list of the initiators (WWPN or IQN) in the initiator group.
  • Grant Access to Host
    The host name to give the application access to.
Details for MongoDB Applications
You enter the following information to provision MongoDB applications or edit the settings:
  • Database Name
  • Data Set Size
  • ONTAP Service Level for Data Set
  • Replication Factor
    Mandatory: The number of replications.
  • Mapping for Primary Host
    Mandatory: The name of primary host.
  • Mapping for Replica Host 1
    Mandatory: The name of first host replica.
  • Mapping for Replica Host 2
    Mandatory: Name of second host replica.
Details for Virtual Desktop Applications
You enter the following information to provision virtual desktop infrastructures (VDI) or edit the settings:
  • Average Desktop Size (used for the SAN Virtual Desktop)
    This is used to determine the thin-provisioned size of each volume in units of MB, GB, TB, or PB.
  • Desktop Size
    This is used to determine the size of the volumes which should be provisioned in units of MB, GB, TB, or PB.
  • ONTAP Service Level for Desktops
  • Number of Desktops
    This number is used to determine the number of volumes created.
    Note
    This is not used to provision the virtual machines.
  • Select Hypervisor
    The hypervisor used for these volumes; the hypervisor determines the correct datastore protocol. The options are VMware, Hyper-V, or XenServer/KVM.
  • Desktop Persistence
    Determines if the desktop is persistent or nonpersistent. Selecting the desktop persistence sets the default values for the volume such as Snapshot schedules and post-process deduplication policies. Inline efficiencies are enabled by default for all volumes.
    Note
    These policies can be modified manually after provisioning.
  • Datastore Prefix
    The value entered is used to generate the names of the datastores and, if applicable, the export policy name or share name.
  • Export Protocol
  • Initiators
Initiator Details
You enter the following information to set up the initiator:
  • Initiator Group
    You can select an existing group or create a new group.
  • Initiator Group Name
    The name of the new initiator group.
  • Initiators
The following fields apply only to SAP HANA provisioning:
  • Initiator OS Type
    The operating system type of the new initiator group.
  • FCP Portset
    The FCP portset that the initiator group is bound to.
Host Access Configuration
You enter the following information to configure the host access to the volumes:
  • Volume Export Configuration
    Select the export policy to apply to the volumes during creation. The options are:
    • Allow All
      This option implies that an export rule is created which permits read-write access to any clients.
    • Create Custom Policy
      This option allows you to specify a list of host IP addresses to receive read-write access.
    Note
    You can modify the volume export policy later using System Manager workflows.
  • Host IP Addresses
    This is a comma-separated list of IP addresses.
    Note
    For NFS-based systems, a new export policy is created using the datastore prefix and a rule is created in it to give access to the list of IP.
Application Details
When the application is added, you can view the configuration settings in the Overview tab of the Application Details window. Other details such as NFS or CIFS Access and Permissions are displayed depending on the type of application that was set up.
  • Type
    This is the type of general application, database, or virtual infrastructure that was created.
  • SVM
    The name of the server virtual machine that the application was created on.
  • Size
    The total size of the volume.
  • Available
    The amount of space currently available in the volume.
  • Protection
    The type of data protection configured.
You can expand the Components and Volumes panes for performance details about space used, IOPs, and latency.
Note
The used size displayed in the Components pane is different than the used size displayed in the CLI.
