Application-specific LUN settings with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
ONTAP System Manager classic (available in ONTAP 9.7 and earlier) supports Oracle, SQL, and other application types while creating FC SAN optimized LUNs on an AFF cluster. LUN settings such as the LUN size are determined by rules specific to the application type. For SQL and Oracle, LUN settings are automatically created.
If your cluster contains two or more nodes, System Manager uses only the first two nodes selected by the API to create LUNs. Data aggregates are already created in each of the two nodes. The size of each volume created is equal to the available capacity of the aggregate. The volumes are thin-provisioned and space reservation is disabled on the LUNs.
Storage efficiency policy is enabled by default with the schedule set to “daily” and quality of service (QoS) set to “best_effort”. By default, access time (atime) update is enabled on the cluster. However, access time updates are disabled by System Manager while creating volumes and therefore every time a file is read or written, the access time field in the directory is not updated.
Note
Enabling the access time update causes performance degradation to the data-serving capability of the cluster.
LUN settings for SQL
By default, LUNs and volumes are provisioned for a single instance of the SQL server with 2 databases of 1 TB each and 24 physical cores. Space is provisioned for LUNs and volumes according to specific rules for the SQL server. Load balancing is performed for LUNs across the HA pair. You can modify the number of databases. For each database, eight data LUNs and one log LUN is created. One temporary LUN is created for each SQL instance.
The following table provides information about how space is provisioned for the default values of SQL:
Node Aggregate LUN type Volume name LUN name Formula for LUN size LUN size (GB)
node1
node1_aggr1
data
db01_data01
db01_data01
Database size ÷ 8
125
data
db01_data02
db01_data02
Database size ÷ 8
125
data
db01_data03
db01_data03
Database size ÷ 8
125
data
db01_data04
db01_data04
Database size ÷ 8
125
data
db02_data01
db02_data01
Database size ÷ 8
125
data
db02_data02
db02_data02
Database size ÷ 8
125
data
db02_data03
db02_data03
Database size ÷ 8
125
data
db02_data04
db02_data04
Database size ÷ 8
125
log
db01_log
db01_log
Database size ÷ 20
50
temp
sql_temp
sql_temp
Database size ÷ 3
330
node2
node2_aggr1
data
db01_data05
db01_data05
Database size ÷ 8
125
data
db01_data06
db01_data06
Database size ÷ 8
125
data
db01_data07
db01_data07
Database size ÷ 8
125
data
db01_data08
db01_data08
Database size ÷ 8
125
data
db02_data05
db02_data05
Database size ÷ 8
125
data
db02_data06
db02_data06
Database size ÷ 8
125
data
db02_data07
db02_data07
Database size ÷ 8
125
data
db02_data08
db02_data08
Database size ÷ 8
125
log
db02_log
db02_log
Database size ÷ 20
50
LUN settings for Oracle
By default, LUNs and volumes are provisioned for one database of 2 TB. Space is provisioned for LUNs and volumes according to specific rules for Oracle. By default, Oracle Real Application Clusters (RAC) is not selected.
The following table provides information about how space is provisioned for the default values of Oracle:
node1
node1_aggr1
data
ora_vol01
ora_lundata01
Database size ÷ 8
250
data
ora_vol02
ora_lundata02
Database size ÷ 8
250
data
ora_vol03
ora_lundata03
Database size ÷ 8
250
data
ora_vol04
ora_lundata04
Database size ÷ 8
250
log
ora_vol05
ora_lunlog1
Database size ÷ 40
50
binaries
ora_vol06
ora_orabin1
Database size ÷ 40
50
node2
node2_aggr1
data
ora_vol07
ora_lundata05
Database size ÷ 8
250
data
ora_vol08
ora_lundata06
Database size ÷ 8
250
data
ora_vol09
ora_lundata07
Database size ÷ 8
250
data
ora_vol10
ora_lundata08
Database size ÷ 8
250
log
ora_vol11
ora_lunlog2
Database size ÷ 40
50
For Oracle RAC, LUNs are provisioned for grid files. Only two RAC nodes are supported for Oracle RAC.
The following table provides information about how space is provisioned for the default values of Oracle RAC:
node1
node1_aggr1
data
ora_vol01
ora_lundata01
Database size ÷ 8
250
data
ora_vol02
ora_lundata02
Database size ÷ 8
250
data
ora_vol03
ora_lundata03
Database size ÷ 8
250
data
ora_vol04
ora_lundata04
Database size ÷ 8
250
log
ora_vol05
ora_lunlog1
Database size ÷ 40
50
binaries
ora_vol06
ora_orabin1
Database size ÷ 40
50
grid
ora_vol07
ora_lungrid1
10 GB
10
node2
node2_aggr1
data
ora_vol08
ora_lundata05
Database size ÷ 8
250
data
ora_vol09
ora_lundata06
Database size ÷ 8
250
data
ora_vol10
ora_lundata07
Database size ÷ 8
250
data
ora_vol11
ora_lundata08
Database size ÷ 8
250
log
ora_vol12
ora_lunlog2
Database size ÷ 40
50
binaries
ora_vol13
ora_orabin2
Database size ÷ 40
50
LUN settings for other application type
Each LUN is provisioned in a volume. The space is provisioned in the LUNs based on the specified size. Load balancing is performed across the nodes for all the LUNs.
