Disks window in System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use the Disks window in ONTAP System Manager classic (avaiable in ONTAP 9.7 and earlier) to view all the disks in your storage system.
Command buttons
  • Assign
    Assigns or reassigns the ownership of the disks to a node.
    This button is enabled only if the container type of the selected disks is unassigned, spare, or shared.
  • Zero Spares
    Erases all the data, and formats the spare disks and array LUNs.
  • Refresh
    Updates the information in the window.
Tabs
Summary
Displays detailed information about the disks in the cluster, including the size of the spare disks and assigned disks. The tab also graphically displays information about spare disks, aggregates, and root aggregates for HDDs and information about spare disks, disks in a storage pool, aggregates, Flash Pool aggregates, and root aggregates for cache disks (SSDs).
The HDD panel is not displayed for systems with All Flash Optimized personality.
The details panel provides additional information about partitioned and unpartitioned spare disks (disk type, node, disk size, RPM, checksum, number of available disks, and spare capacity), in tabular format.
Inventory
  • Name
    Displays the name of the disk.
  • Container Type
    Displays the purpose for which the disk is used. The possible values are Aggregate, Broken, Foreign, Label Maintenance, Maintenance, Shared, Spare, Unassigned, Volume, Unknown, and Unsupported.
  • Partition Type
    Displays the partition type of the disk.
  • Node Name
    Displays the name of the node that contains the aggregate.
    This field is available only at the cluster level.
  • Home owner
    Displays the name of the home node to which this disk is assigned.
  • Current owner
    Displays the name of the node that currently owns this disk.
  • Root owner
    Displays the name of the node that currently owns the root partition of this disk.
  • Data Owner
    Displays the name of the node that currently owns the data partition of this disk.
  • Data1 Owner
    Displays the name of the node that currently owns the data1 partition of the disk.
  • Data2 Owner
    Displays the name of the node that currently owns the data2 partition of the disk.
  • Storage Pool
    Displays the name of the storage pool with which the disk is associated.
  • Type
    Displays the type of the disk.
  • Firmware Version
    Displays the firmware version of the disk.
  • Model
    Displays the model of the disk.
  • RPM
    Displays the effective speed of the disk drive when the option raid.mix.hdd.rpm.capacity is enabled, and displays the actual speed of the disk drive when the option raid.mix.hdd.rpm.capacity is disabled.
    This field is not applicable to SSDs.
  • Effective Size
    Displays the usable space available on the disk.
  • Physical Space
    Displays the total physical space of the disk.
  • Shelf
    Displays the shelf on which the physical disks are located.
    This field is hidden by default.
  • Bay
    Displays the bay within the shelf for the physical disk.
  • Pool
    Displays the name of the pool to which the selected disk is assigned.
  • Checksum
    Displays the type of the checksum.
  • Carrier ID
    Specifies information about disks that are located within the specified multi-disk carrier. The ID is a 64-bit value.
Inventory details area
The area below the inventory tab displays detailed information about the selected disk, including information about the aggregate or volume (if applicable), vendor ID, zeroing state (in percent), serial number of the disk, and error details in case of a broken disk. For shared disks, the Inventory details area displays the names of all the aggregates, including the root and the non-root aggregates.
Related information
