Manage home directory paths - ONTAP 9.7 and earlier
Contributors netapp-aoife NetAppZacharyWambold
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to specify one or more paths that can be used by the storage system to resolve the location of the CIFS home directories of users.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Home Directories area of the Configuration tab, click Manage.
  4. In the Manage Home Directories dialog box, specify the paths that are to be used by the storage system to search for the CIFS home directories of users.
  5. Click Add, and then click Save and Close.
Delete home directory paths
You can use System Manager to delete a home directory path when you do not want the storage system to use the path to resolve the location of the CIFS home directories of users.
Steps
  4. In the Manage Home Directories dialog box, select the home directory path that you want to delete, and then click Delete.
  5. Click Save and Close.
Related information
