Change the deduplication schedule with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the deduplication schedule by choosing to run deduplication manually, automatically, or on a schedule that you specify.
Steps
  1. Click Storage > Volumes.
  2. From the drop-down menu in the SVM field, select All SVMs.
  3. Select the read/write volume for which you want to modify the deduplication schedule.
  4. Click Edit, and then click the Storage Efficiency tab.
  5. Change the deduplication schedule as required.
  6. Click Save and Close.
Related information
