Changing the status of a FlexCache volume
Contributors netapp-thomi
Beginning with System Manager 9.6, you can change the status of a FlexCache volume when you want to take it offline, bring a FlexCache volume back online, or restrict access to a FlexCache volume.
Steps
  1. Click Storage > Volumes.
  2. From the drop-down menu in the SVM field, select All SVMs.
  3. Select the FlexCache volume for which you want to modify the status.
  4. Click More Actions > Change status to, and then update the FlexCache volume status by selecting the required status.
    Note
    To take a FlexCache volume offline and to change the status to "restricted", you must first unmount the volume.
