Change the status of a FlexGroup volume with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the status of a FlexGroup volume when you want to take a FlexGroup volume offline, bring a FlexGroup volume back online, or restrict access to a FlexGroup volume.
About this task
System Manager does not support constituent-level management for FlexGroup volumes.
Steps
  1. Click Storage > Volumes.
  2. From the drop-down menu in the SVM field, select All SVMs.
  3. Select the FlexGroup volume for which you want to modify the status.
  4. Click More Actions > Change status to, and then update the FlexGroup volume status by selecting the required status.
Related information
