Configure NVMe protocol on SVMs with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife NetAppZacharyWambold
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to configure the NVMe protocol on a storage virtual machine (SVM). You can then create namespaces and assign them to an NVMe subsystem and host.
About this task
The SVM with NVMe should not have any other protocol. If you select NVMe, then the rest of the protocols will be disabled. You can also configure NVMe while creating the SVM.
Steps
  1. If you did not configure the NVMe protocol when creating the SVM, click Storage > SVMs
  2. Select the SVM, and then click SVM settings.
  3. In the Protocols pane, click NVMe.
  4. Click the link to configure the protocol, as required.
    Note
    If there are any other protocols enabled, you must deselect these to make NVMe available to select. NVMe cannot be combined with any other protocol.
  5. In the Edit Storage Virtual Machine pane, click on Resource Allocation.
  6. In the Resource Allocation tab, you can choose not to delegate volume creation or you can select an aggregate to provision the volumes automatically.
  7. Click on the Services tab to configure the Name Service Switch details.
  8. Click Save and Close
    The NVMe protocol is configured on the SVM. After the protocol has been configured, you can start or stop the service using SVM Settings
Related information
