Configure System Manager options - ONTAP 9.7 and earlier
Contributors netapp-aoife NetAppZacharyWambold
You can enable logging and specify the inactivity timeout value for ONTAP System Manager classic (available in ONTAP 9.7 or earlier).
About this task
You can configure the options from the System Manager login window. However, you must log in to the application to specify the inactivity timeout value.
Steps
  1. Click nas bridge 202 icon settings olh 96 97.
  2. In the Setup pane, click General.
  3. Specify a log level.
  4. Specify the inactivity timeout value in minutes.
    Note
    This option is not available if you have enabled Security Assertion Markup Language (SAML) authentication.
  5. Click OK.
