Delete LUNs with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to delete LUNs and return the space used by the LUNs to their containing aggregates or volumes.
Before you begin
  • The LUN must be offline.
  • The LUN must be unmapped from all initiator hosts.
Steps
  1. Click Storage > LUNs.
  2. In the LUN Management tab, select one or more LUNs that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Delete.
Related information
