Edit an application with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to edit a provisioned application to increase to storage size or to manage the Snapshot copies of the application.
About this task
As the cluster administrator, after you provision an application, you can edit it to modify the storage size. You can also create, restore, or delete Snapshot copies of the application. The example procedure that follows describes how to edit a NAS Container application.
Steps
  1. Click Applications & Tiers > Applications
  2. Click on the name of the NAS container application.
    Note
    If someone adds new applications using the CLI or REST API while you are viewing the list of applications, then you will not be able to view those new applications when you scroll the list.
    The Overview tab of the Application Details: nas window displays the application settings.
  3. Click Edit.
    The Edit NAS Container: nas displays the current storage size setting and the NFS Access - Grant Access to Host address.
  4. Modify the Storage Total Size value.
  5. In the size units field, select from the drop-down menu to specify the correct size units (Bytes, MB, GB, or TB).
  6. In the ONTAP Service Level field, select from the drop-down menu to specify the value.
  7. Click Save.
  8. Navigate back to the Application Details: nas window, and select the Snapshot Copiestab.
    A list of Snapshot copies for this provisioned application is displayed. You can use the Search field to search for Snapshot copies by name.
  9. Manage the Snapshot copies by performing the following tasks as necessary:
    Task Actions
    Create
    Click Create to create a new Snapshot copy.
    Restore
    Click the check boxes next to the Snapshot copies you want to restore, and then click Restore.
    Delete
    Click the check boxes next to the Snapshot copies you want to delete, and then click Delete.
