Editing FlexCache volumes
Contributors netapp-thomi
Beginning with System Manager 9.6, you can edit the properties of an existing FlexCache volume.
Steps
  1. Click Storage > Volumes.
  2. From the drop-down menu in the SVM field, select All SVMs.
  3. Select the FlexCache volume that you want to modify, and click Edit.
  4. Optional: Enter a new name for the FlexCache volume in the Volume field under FlexCache Volume.
  5. Optional: Enter a new size for the FlexCache volume in the Size field under FlexCache Volume, and select the measurement unit from the drop-down menu.
  6. Optional: Enable or disable encryption.
  7. Optional: Click advanced options to modify the FlexCache volume advanced settings. Refer to Setting advanced settings for FlexCache volumes.
  8. Click Save to save the changes.
Related information
