Install a CA certificate if you use StorageGRID with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife NetAppZacharyWambold
For ONTAP to authenticate with StorageGRID as the object store for a FabricPool-enabled aggregate, you can install a StorageGRID CA certificate on the cluster with System Manager classic (available in ONTAP 9.7 and earlier).
Steps
  1. Follow the StorageGRID system documentation to copy the CA certificate of the StorageGRID system by using the Grid Management Interface.
    While adding StorageGRID as a cloud tier, a message is displayed if the CA certificate is not installed.
  2. Add the StorageGRID CA certificate.
    Note
    The fully qualified domain name (FQDN) that you specify must match the custom common name on the StorageGRID CA certificate.
Related information
