Mirror aggregates with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to protect data and to provide increased resiliency by mirroring data in real-time, within a single aggregate. Mirroring aggregates removes single points of failure in connecting to disks and array LUNs.
Before you begin
There must be sufficient free disks in the other pool to mirror the aggregate.
About this task
You cannot mirror a Flash Pool aggregate when the cache source is storage pool.
Steps
  1. Choose one of the following methods:
    • Click Applications & Tiers > Storage Tiers.
    • Click Storage > Aggregates & Disks > Aggregates.
  2. Select the aggregate that you want to mirror, and then click More Actions  Mirror.
    Note
    SyncMirror is not supported on FabricPool-enabled aggregates.
  3. In the Mirror this aggregate dialog box, click Mirror to initiate the mirroring.
