Provision cache by adding SSDs with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to add SSDs as either storage pools or dedicated SSDs to provision cache. By adding SSDs, you can convert a non-root aggregate or a root aggregate that does not contain partitioned disks to a Flash Pool aggregate, or increase the cache size of an existing Flash Pool aggregate.
About this task
  • The added SSD cache does not add to the size of the aggregate, and you can add an SSD RAID group to an aggregate even when it is at the maximum size.
  • You cannot use partitioned SSDs when you add cache by using System Manager.
Provisioning cache to aggregates by adding SSDs
You can use System Manager to add storage pools or dedicated SSDs to provision cache by converting an existing non-root HDD aggregate or a root aggregate that does not contain partitioned disks to a Flash Pool aggregate.
Before you begin
  • The aggregate must be online.
  • There must be sufficient spare SSDs or allocation units in the storage pool that can be assigned as cache disks.
  • All of the nodes in the cluster must be running ONTAP 8.3 or later.
    If the cluster is in a mixed-version state, you can use the command-line interface to create a Flash Pool aggregate and then provision SSD cache.
  • You must have identified a valid 64-bit non-root aggregate composed of HDDs that can be converted to a Flash Pool aggregate.
  • The aggregate must not contain any array LUNs.
About this task
You must be aware of platform-specific and workload-specific best practices for Flash Pool aggregate SSD tier size and configuration.
Steps
  1. Choose one of the following methods:
    • Click Applications & Tiers > Storage Tiers.
    • Click Storage > Aggregates & Disks > Aggregates.
  2. In the Storage Tiers window, select the aggregate, and then click More Actions > Add Cache.
    Note
    Adding cache is not supported on FabricPool-enabled aggregates.
  3. In the Add Cache dialog box, perform the appropriate action:
    If you selected the cache source as…​ Do this…​
    Storage pools
    1. Select the storage pool from which cache can be obtained.
    2. Specify the cache size.
    3. Modify the RAID type, if required.
    Dedicated SSDs
    Select the SSD size and the number of SSDs to include, and optionally modify the RAID configuration:
    1. Click Change.
    2. In the Change RAID Configuration dialog box, specify the RAID type and RAID group size, and then click Save.
  4. Click Add.
    For mirrored aggregates, an Add Cache dialog box is displayed with the information that twice the number of selected disks will be added.
  5. In the Add Cache dialog box, click Yes.
Results
The cache disks are added to the selected aggregate.
Increasing the cache for Flash Pool aggregates by adding SSDs
You can add SSDs as either storage pools or dedicated SSDs to increase the size of a Flash Pool aggregate by using System Manager.
Before you begin
  • The Flash Pool aggregate must be online.
Steps
  1. Click Storage > Aggregates & Disks > Aggregates.
  2. In the Aggregates window, select the Flash Pool aggregate, and then click Add Cache.
    Storage pools
    Select the storage pool from which cache can be obtained, and specify the cache size.
    Dedicated SSDs
    Select the SSD size and the number of SSDs to include.
  4. Click Add.
Results
The cache disks are added to the selected Flash Pool aggregate.
Related information
