Delete a volume replication relationship
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can use the snapmirror delete
and snapmirror release
commands to delete a volume replication relationship. You can then delete unneeded destination volumes manually.
The snapmirror release
command deletes any SnapMirror-created Snapshot copies from the source. You can use the -relationship-info-only
option to preserve the Snapshot copies.
Quiesce the replication relationship:
snapmirror quiesce -destination-path SVM:volume|cluster://SVM/volume
cluster_dst::> snapmirror quiesce -destination-path svm_backup:volA_dst
(Optional) Break the replication relationship if you require the destination volume to be a read/write volume. You can skip this step if you plan to delete the destination volume or if you don't need the volume to be read/write:
snapmirror break -source-path SVM:volume|cluster://SVM/volume, … -destination-path SVM:volume|cluster://SVM/volume, …
cluster_dst::> snapmirror break -source-path svm1:volA -destination-path svm_backup:volA_dst
Delete the replication relationship:
snapmirror delete -source-path SVM:volume|cluster://SVM/volume, … -destination-path SVM:volume|cluster://SVM/volume, …
For complete command syntax, see the man page.
You must run this command from the destination cluster or destination SVM.
The following example deletes the relationship between the source volume
volA
onsvm1
and the destination volumevolA_dst
onsvm_backup
:cluster_dst::> snapmirror delete -source-path svm1:volA -destination-path svm_backup:volA_dst
Release replication relationship information from the source SVM:
snapmirror release -source-path SVM:volume|cluster://SVM/volume, … -destination-path SVM:volume|cluster://SVM/volume, …
You must run this command from the source cluster or source SVM.
The following example releases information for the specified replication relationship from the source SVM
svm1
:cluster_src::> snapmirror release -source-path svm1:volA -destination-path svm_backup:volA_dst
