Astra Automation
이 제품의 최신 릴리즈를 사용할 수 있습니다.
Execution Hook overview
기여자
The Execution Hook API provides CRUD (Create-Read-Update-Delete) access to executionHook resources in order to allow simple management of execution hooks. Execution hooks contain additional configuration and references to a hook source resource.
