Astra Automation
이 제품의 최신 릴리즈를 사용할 수 있습니다.
Create a new cloud
기여자
POST /accounts/{account_id}/topology/v1/clouds
Indicates the desired values for the Cloud API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
Request Body
type
string
True
  • "application/astra-cloud"
version
string
True
  • "1.0"
  • "1.1"
name
string
True
JSON string containing the name of the cloud. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks
cloudType
string
True
JSON string containing a value indicating the type of cloud. Defined values are:
  • "gcp" - The cloud is provided by Google
  • "azure" - The cloud is provided by Microsoft
  • "aws" - The cloud is provided by Amazon
  • "private" - The cloud is customer managed
credentialID
string
False
JSON string containing a value indicating the ID of the credential that contains the service account for the cloud. This is required for cloudType "gcp", "azure" and "aws". Defined values are:
  • Conforms to the Astra Identifier Schema
defaultBucketID
string
False
JSON string containing the ID of a bucket that is to be used by default when creating backups for applications within the cloud. This is required when cloning applications across clusters and is used as a default if a bucket is not specified when creating backups and schedules. Defined values are:
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-cloud",
  "version": "1.1",
  "name": "GKE",
  "cloudType": "gcp",
  "credentialID": "6fa2f917-f730-41b8-9c15-17f531843b31"
Status: 201, Returns the newly created cloud resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
  • Minimum length: 1
state
string
True
JSON string containing a value indicating the operational state of the cloud. Defined values are:
  • "pending" - The cloud is scheduled for discovery
  • "discovering" - The cloud is in the process of being discovered
  • "provisioning" - The cloud is in the process of being provisioned
  • "running" - The cloud is running normally
  • "failed" - The cloud is in a permanent failure state
  • "removed" - The cloud is not currently accessible
  • "unknown" - The cloud state cannot be determined
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why a cloud is unable to transition to "running" or why it has transitioned to "failed". Defined values are:
  • Minimum length: 1
  • Maximum length: 127
cloudType
string
True
credentialID
string
False
defaultBucketID
string
False
metadata
True
  "version": "1.1",
  "id": "1c9512c3-ec62-5ed8-8013-02fc090b9d03",
  "name": "GKE",
  "state": "discovering",
  "stateUnready": [
    "Cloud discovery in progress"
  "cloudType": "gcp",
  "credentialID": "6fa2f917-f730-41b8-9c15-17f531843b31",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
