Astra Automation
Retrieve a role binding
Colaboradores
GET /accounts/{account_id}/core/v1/roleBindings/{roleBinding_id}
Returns the stored Role Binding API resource in the JSON response body. If the request is against /accounts/{account_id}/core/v1/users/{user_id}/roleBindings endpoint, only roleBinding resources where the user ID matches the user ID in the request URL will be permitted to be read. If the request is against /accounts/{account_id}/core/v1/groups/{group_id}/roleBindings, only roleBinding resources where the group ID matches the group ID in the request URL will be permitted to be read.
account_id
string
path
True
  • example: {{.Account}}
roleBinding_id
string
path
True
ID of the roleBinding collection to list
Status: 200
type
string
True
  • "application/astra-roleBinding"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
principalType
string
True
JSON string representing the type of the principal this binding is associated with. Defined values are:
  • "user"
  • "group" For principalType "user", a non-nil user ID is required. For principalType "group", a non-nil group ID is required.
userID
string
True
JSON string containing a user resource ID. Defined values are:
  • Conforms to the Astra Identifier Schema If not specified on create, a nil UUID will be used. Only userID or groupID can be specified on create.
groupID
string
True
JSON string containing a group resource ID. Defined values are:
accountID
string
True
JSON string containing the ID of an account resource. For create, this must match the account ID in the request URI. Defined values are:
role
string
True
JSON string containing one of the four defined roles. Defined values are:
  • "viewer"
  • "member"
  • "admin"
  • "owner"
roleConstraints
array[string]
False
JSON array of JSON strings specifying the scope of the role assignment. Defined values are:
  • Conforms to Astra Role Constraints Schema If not specified on create, the value will be set to an array of size 1 containing string "*" representing "full scope". If not specified on update, the value will be preserved without modification. An empty array represents "no scope". Examples:
  • = Allow access to any resource: "roleConstraints": ["*"]
  • = deny access to all resources: "roleConstraints": []
  • = Allow access to a specific namespace resource only: "roleConstraints": [ "namespaces:id='6fa2f917-f730-41b8-9c15-17f531843b31'" ]
  • = Allow access to a specific namespace and everything under it: "roleConstraints": [ "namespaces:id='6fa2f917-f730-41b8-9c15-17f531843b31'.*" ]
  • = Allow access to all namespaces labelled "dev" in any cluster in any cloud, and everything under them: "roleConstraints": [ "namespaces:kubernetesLabels='dev.example.com/appname=dev'.*" ]
  • = Allow access to all namespace resources only: "roleConstraints": [ "namespaces:*" ]
  • = Allow access to all namespace resources and everything under them: "roleConstraints": [ "namespaces:." ]
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-roleBinding",
  "version": "1.1",
  "id": "a198f052-5cd7-59d3-9f27-9ea32a21fbca",
  "principalType": "user",
  "userID": "4c27d25a-9edb-4e85-9438-48dc8e917231",
  "groupID": "00000000-0000-0000-0000-000000000000",
  "accountID": "9fd87309-067f-48c9-a331-527796c14cf3",
  "role": "viewer",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
