Astra Automation
List application assets for an application snapshot
Colaboradores
GET /accounts/{account_id}/k8s/v1/apps/{app_id}/appSnaps/{appSnap_id}/appAssets
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
appSnap_id
string
path
True
ID of the containing appSnap resource
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: assetType,assetName
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: appAsset_1.1_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-appAssets",
  "version": "1.1",
  "items": [
      "Pod",
      "mediawiki-69c6fcf864-2wx6l"
      "ReplicaSet",
      "mediawiki-69c6fcf864"
      "Service",
      "mediawiki"
      "Deployment",
      "mediawiki"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
GVK
JSON object containing a Kubernetes group/version/kind.
group
string
False
JSON string containing a group identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
  • Maximum length: 254
kind
string
False
JSON string containing a kind identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
version
string
False
JSON string containing a version identifier assigned by Kubernetes. Defined values are:
  • Minimum length: 1
type_json
JSON object containing the entire content of the Kubernetes resource definition.
labels
name
string
True
JSON string containing the label name Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Defined regex is: "^([\S.]{1,253}\/)?([a-z0-9A-Z_.-]){1,63}$"
value
string
True
JSON string containing the label value Defined values are:
  • Minimum length: 1
  • Defined regex is: "^([a-z0-9A-Z_.-]){1,63}$"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-appAsset"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
assetType
string
True
JSON string containing a value indicating what type of asset is being described as obtained from Kubernetes. Defined values are:
  • Minimum length: 1
creationTimestamp
string
True
JSON string containing a timestamp indicating when the Kubernetes metadata was created. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
GVK
GVK
True
resource
type_json
False
assetID
string
True
JSON string containing an identifier assigned by Kubernetes. Defined values are:
  • Conforms to the Astra Identifier Schema
labels
array[labels]
True
JSON array of JSON objects, each containing a Kubernetes labels associated with the asset. If no details are available, this array will be empty.
  • Minimum items: 0
assetName
string
True
JSON string containing a name assigned by Kubernetes. Defined values are:
  • Minimum length: 1
namespace
string
False
JSON string containing a namespace assigned by Kubernetes. Defined values are:
  • Minimum length: 1
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
