Astra Automation
Retrieve an execution hook override resource
GET /accounts/{account_id}/k8s/v1/apps/{app_id}/executionHookOverrides/{executionHookOverride_id}
Returns the stored Execution Hook Override API resource in the JSON response body.
Cuidado This operation is deprecated.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
string
path
True
ID of the executionHookOverride collection to list
Status: 200, Returns the stored Execution Hook Override API resource in the JSON response body.
type
string
True
  • "application/astra-executionHookOverride"
version
string
True
  • "1.0"
id
string
True
executionHookID
string
True
JSON string containing the ID of an execution hook. Defined values are:
  • Conforms to the Astra Identifier Schema Only allows the executionHookID of an execution hook resource with a hookType value of "netapp".
enabled
string
True
JSON string that indicates whether the execution hook is enabled for the specified application. Defined values are:
  • "true" - The execution hook is enabled and will run in a specified order
  • "false" - The execution hook is disabled and cannot run
appID
string
True
JSON string containing the associated ID of the application with which the override is linked. Defined values are:
metadata
type_astra_metadata_update
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
  "type": "application/astra-executionHookOverride",
  "version": "1.0",
  "id": "c11af802-5e53-5897-8cd9-2de730494be3",
  "executionHookID": "eb863cc6-0d9a-454d-8ef7-81b7cac91929",
  "enabled": "false",
  "appID": "4b43c2f7-bffa-4f60-b595-d98a05b64bc9",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
