Astra Automation
Create a new execution hook override resource for an app
Colaboradores
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/executionHookOverrides
Indicates the desired values for the Execution Hook Override API resource to be created.
Cuidado This operation is deprecated.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
Request Body
type
string
True
  • "application/astra-executionHookOverride"
version
string
True
  • "1.0"
executionHookID
string
True
JSON string containing the ID of an execution hook. Defined values are:
  • Conforms to the Astra Identifier Schema Only allows the executionHookID of an execution hook resource with a hookType value of "netapp".
enabled
string
True
JSON string that indicates whether the execution hook is enabled for the specified application. Defined values are:
  • "true" - The execution hook is enabled and will run in a specified order
  • "false" - The execution hook is disabled and cannot run
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-executionHookOverride",
  "version": "1.0",
  "executionHookID": "eb863cc6-0d9a-454d-8ef7-81b7cac91929",
  "enabled": "false"
Status: 201, Returns the newly created executionHookOverride resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
id
string
True
executionHookID
string
True
enabled
string
True
appID
string
True
JSON string containing the associated ID of the application with which the override is linked. Defined values are:
metadata
True
  "version": "1.0",
  "id": "c11af802-5e53-5897-8cd9-2de730494be3",
  "enabled": "false",
  "appID": "4b43c2f7-bffa-4f60-b595-d98a05b64bc9",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
