Active IQ Unified Manager
Create a report to group volume relationships by issue in Active IQ Unified Manager
You can create a report that groups volume relationships by issue.
Before you begin
  • You must have the Application Administrator or Storage Administrator role.
Use the following steps to create a custom view that groups volume relationships by issue, and then schedule a report to be generated for that view.
Steps
  1. In the left navigation pane, click Storage > Volumes.
  2. In the View menu, select Relationship > All Relationships.
  3. Select Show/Hide to remove any columns you do not want in the report.
  4. Drag the “Unhealthy Reason” column near the “State” column.
  5. Click the top of the “Unhealthy Reason” column to group the volumes by issue.
  6. Save the view with a specific name that reflects what the view is showing, for example, “Vol relationships by issue”.
  7. Click the Scheduled Reports button on the inventory page.
  8. Enter a name for the report schedule and complete the other report fields, then click the check mark (blue check) at the end of the row.
    The report is sent immediately as a test. After that, the report generates and is sent by email to the recipients listed using the specified frequency.
Based on the results shown in the report, you can investigate the source and impact of each type of issue.
