Active IQ Unified Manager
9.7
Edit Annotation Rule dialog box
You can edit the annotation rules you created to add or remove annotations on storage objects.
You must have the Application Administrator or Storage Administrator role.
  • Name
    Displays the name of the annotation rule.
  • Target Object Type
    Displays the type of storage object that you want to annotate. You cannot change the object type.
  • Apply Annotation
    Displays the annotation and the value you can use to annotate storage objects when all conditions are met.
  • Conditions
    Displays the list of conditions for the annotation rule. You can edit the conditions to add or remove the annotation on storage objects.
Command buttons
  • Save
    Saves the changes you made and closes the Edit Annotation Rule dialog box.
  • Cancel
    Closes the Edit Annotation Rule dialog box without saving your changes.
