Active IQ Unified Manager
9.7
Relationship Thresholds page
The Relationship Thresholds page enables you to configure global lag warning and error threshold values for unmanaged protection relationships so that you are notified and can take action when lag or threshold errors occur. Changes to these settings are applied during the next scheduled update.
You must have the Application Administrator or Storage Administrator role.
Events are generated when a threshold is breached. You can take corrective actions for such events. Lag threshold settings for unmanaged relationships are enabled by default.
The lag threshold specifies a percentage that the lag time must not exceed. Using an example of one hour, if the lag threshold is defined as 150%, then you will receive an event when the lag time is more than 1.5 hours.
Lag Thresholds for Unmanaged Relationships area
The Lag area enables you set unmanaged relationship lag thresholds for the following conditions:
  • Warning
    Specifies the percentage at which the lag duration equals or exceeds the lag warning threshold:
    • Default value: 150 percent
    • Events generated: SnapMirror Relationship Lag Warning or SnapVault Relationship Lag Warning
    • Event severity: Warning
  • Error
    Specifies the percentage at which the lag duration equals or exceeds the lag error threshold:
    • Default value: 250 percent
    • Events generated: SnapMirror Relationship Lag Error or SnapVault Relationship Lag Error
    • Event severity: Error
Additionally, you can disable a warning or error event from being triggered from any lag threshold amount by unchecking the box next to Enabled.
