Active IQ Unified Manager 9.7
9.7
Reverse Resync dialog box
When you have a protection relationship that is broken because the source volume is disabled and the destination is made a read/write volume, reverse resynchronization enables you to reverse the direction of the relationship so that the destination becomes the new source and the source becomes the new destination.
When a disaster disables the source volume in your protection relationship, you can use the destination volume to serve data by converting it to read/write, while you repair or replace the source, update the source, and reestablish the relationship. When you perform a reverse resync operation, data on the source that is newer than the data on the common Snapshot copy is deleted.
Before reverse resync
Displays the source and destination of a relationship before a reverse resync operation.
  • Source Volume
    The name and location of the source volume before a reverse resync operation.
  • Destination Volume
    The name and location of the destination volume before a reverse resync operation.
After reverse resync
Displays what the source and destination of a relationship is after a reserve resync operation.
  • Source Volume
    The name and location of the source volume after a reverse resync operation.
    The name and location of the destination volume after a reverse resync operation.
Command buttons
The command buttons enable you to perform the following actions:
  • Submit
    Begins the reverse resynchronization process.
  • Cancel
    Closes the Reverse Resync dialog box without initiating a reverse resync operation.
