Active IQ Unified Manager 9.8
9.8
Aggregates dialog box
You can use the Aggregates dialog box to select the aggregates that you want to add to your resource pool.
Command buttons
The command buttons enable you to perform the following tasks:
  • Add
    Adds the selected aggregates to the resource pool. The Add button is not enabled until at least one aggregate is selected.
  • Cancel
    Discards the changes, and closes the Aggregates dialog box.
Aggregates list
The Aggregates list displays (in tabular format) the names and properties of monitored aggregates.
  • Status
    Displays the current status of a volume. The status can be Critical (sev critical um60), Error (sev error um60), Warning (sev warning um60), or Normal (sev normal um60).
    You can move the pointer over the status to view more information about the event or events generated for the volume.
  • Aggregate Name
    Displays the name of the aggregate.
  • State
    Displays the current state of the aggregate, which can be one of the following:
    • Offline
      Read or write access is not allowed.
    • Restricted
      Limited operations (such as parity reconstruction) are allowed, but data access is not allowed.
    • Online
      Read and write access to the volumes that are hosted on this aggregate is allowed.
    • Creating
      The aggregate is being created.
    • Destroying
      The aggregate is being destroyed.
    • Failed
      The aggregate cannot be brought online.
    • Frozen
      The aggregate is (temporarily) not serving requests.
    • Inconsistent
      The aggregate has been marked corrupted; you should contact technical support.
    • Iron Restricted
      Diagnostic tools cannot be run on the aggregate.
    • Mounting
      The aggregate is in the process of mounting.
    • Partial
      At least one disk was found for the aggregate, but two or more disks are missing.
    • Quiescing
      The aggregate is being quiesced.
    • Quiesced
      The aggregate is quiesced.
    • Reverted
      The revert of an aggregate is completed.
    • Unmounted
      The aggregate is offline.
    • Unmounting
      The aggregate is being taken offline.
    • Unknown
      The aggregate is discovered, but the aggregate information is not yet retrieved by the Unified Manager server.
  • Cluster
    Displays the name of the cluster on which the aggregate resides.
  • Node
    Displays the name of the storage controller that contains the aggregate.
  • Total Capacity
    Displays the total data size (in MB, GB, and so on) of the aggregate. By default, this column is hidden.
  • Committed Capacity
    Displays the total space (in MB, GB, and so on) that is committed for all the volumes in the aggregate. By default, this column is hidden.
  • Used Capacity
    Displays the amount of space (in MB, GB, and so on) that is used in the aggregate.
  • Available Capacity
    Displays the amount of space (in MB, GB, and so on) that is available for data in the aggregate. By default, this column is hidden.
  • Available %
    Displays the percentage of space that is available for data in the aggregate. By default, this column is hidden.
  • Used %
    Displays the percentage of space that is used by data in the aggregate.
  • RAID Type
    Displays the RAID type of the selected volume. The RAID type can be RAID0, RAID4, RAID-DP, RAID-TEC, or Mixed RAID.
