Aggregates dialog box
PDF of this doc site
Online help
Monitor and manage cluster performance
Monitor and manage cluster health
Creating your file...
You can use the Aggregates dialog box to select the aggregates that you want to add to your resource pool.
Command buttons
The command buttons enable you to perform the following tasks:
Add
Adds the selected aggregates to the resource pool. The Add button is not enabled until at least one aggregate is selected.
Cancel
Discards the changes, and closes the Aggregates dialog box.
Aggregates list
The Aggregates list displays (in tabular format) the names and properties of monitored aggregates.
Status
Displays the current status of a volume. The status can be Critical (
), Error (
), Warning (
), or Normal (
You can move the pointer over the status to view more information about the event or events generated for the volume.
Aggregate Name
Displays the name of the aggregate.
State
Displays the current state of the aggregate, which can be one of the following:
Offline
Read or write access is not allowed.
Restricted
Limited operations (such as parity reconstruction) are allowed, but data access is not allowed.
Online
Read and write access to the volumes that are hosted on this aggregate is allowed.
Creating
The aggregate is being created.
Destroying
The aggregate is being destroyed.
Failed
The aggregate cannot be brought online.
Frozen
The aggregate is (temporarily) not serving requests.
Inconsistent
The aggregate has been marked corrupted; you should contact technical support.
Iron Restricted
Diagnostic tools cannot be run on the aggregate.
Mounting
The aggregate is in the process of mounting.
Partial
At least one disk was found for the aggregate, but two or more disks are missing.
Quiescing
The aggregate is being quiesced.
Quiesced
The aggregate is quiesced.
Reverted
The revert of an aggregate is completed.
Unmounted
The aggregate is offline.
Unmounting
The aggregate is being taken offline.
Unknown
The aggregate is discovered, but the aggregate information is not yet retrieved by the Unified Manager server.
Cluster
Displays the name of the cluster on which the aggregate resides.
Node
Displays the name of the storage controller that contains the aggregate.
Total Capacity
Displays the total data size (in MB, GB, and so on) of the aggregate. By default, this column is hidden.
Committed Capacity
Displays the total space (in MB, GB, and so on) that is committed for all the volumes in the aggregate. By default, this column is hidden.
Used Capacity
Displays the amount of space (in MB, GB, and so on) that is used in the aggregate.
Available Capacity
Displays the amount of space (in MB, GB, and so on) that is available for data in the aggregate. By default, this column is hidden.
Available %
Displays the percentage of space that is available for data in the aggregate. By default, this column is hidden.
Used %
Displays the percentage of space that is used by data in the aggregate.
RAID Type
Displays the RAID type of the selected volume. The RAID type can be RAID0, RAID4, RAID-DP, RAID-TEC, or Mixed RAID.
