Active IQ Unified Manager 9.8
9.8
Fixing issues using Unified Manager automatic remediations
There are certain events that Unified Manager can diagnose thoroughly and provide a single resolution using the Fix It button. When available, those resolutions are displayed in the Dashboard, from the Event details page, and from the Workload Analysis selection on the left-navigation menu.
About this task
Most events have a variety of possible resolutions that are displayed in the Event details page so you can implement the best solution using ONTAP System Manager or the ONTAP CLI. A Fix It action is available when Unified Manager has determined that there is a single resolution to fix the issue, and that it can be resolved using an ONTAP CLI command.
Steps
  1. To view events that can be fixed from the Dashboard, click Dashboard.
    management actions
  2. To resolve any of the issues that Unified Manager can fix, click the Fix It button. To fix an issue that exists on multiple objects, click the Fix All button.
