Node health fields
The following fields are available in the Health: All Nodes view and can be used in custom views and in reports.
Status
An icon that identifies the current status of the node. The status can be Critical (
), Error (
), Warning (
), or Normal (
Node
The name of the node. You can click the node name to navigate to that cluster's node details page.
State
The state of the node. The state can be Up or Down.
HA State
The state of the HA pair. The state can be Error, Warning, Normal, or Not applicable.
Down Time
The time that has elapsed or the timestamp since the node is offline. If the time elapsed exceeds a week, the timestamp when the node went offline is displayed.
All Flash Optimized
Whether the node is optimized to support only solid-state drives (SSDs).
Model/Family
The model of the node.
OS version
The ONTAP software version that the node is running.
Serial Number
The serial number of the node.
Firmware Version
The firmware version number of the node.
Aggregate Used Capacity
The amount of space used for data in the node's aggregates.
Aggregate Total Capacity
The total space available for data in the node's aggregates.
Usable Spare Capacity
The amount of available space in the node that can be used to enhance the aggregate capacity.
Usable Raw Capacity
The amount of space that is usable in the node.
Total Raw Capacity
The capacity of every unformatted disk in the node before right-sizing and RAID configuration.
Storage VM Count
The number of SVMs contained by the cluster.
FC Port Count
The number of FC ports contained by the node.
FCoE Port Count
The number of FCoE ports contained by the node.
Ethernet Port Count
The number of ethernet ports contained by the node.
Flash Card Size
The size of the flash cards installed on the node.
Flash Card Count
The number of flash cards installed on the node.
Disk Shelves Count
The number of disk shelves contained by the node.
Disk Count
The number of disks in the node.
Cluster
The name of the cluster to which the node belongs. You can click the cluster name to navigate to that cluster's health details page.
Cluster FQDN
The fully qualified domain name (FQDN) of the cluster.
Contact
The contact information of the node.
Location
The location of the node.
