Digital Advisor
Learn about generating an ONTAP upgrade plan in Digital Advisor
Contributors netapp-shwetav netapp-manishc netapp-barbe
Upgrade Advisor enables you to generate an upgrade plan that includes detailed and step-by-step information required for a successful ONTAP upgrade or revert.
You can generate automated nondisruptive upgrade plans for a single cluster and multiple clusters. You can view upgrade recommendations for a single cluster, which includes a list of risks associated with a cluster, a pre-upgrade check report containing a list of upgrade blockers and warnings, and information about new features and enhancements. The upgrade recommendations are unavailable for multiple clusters. To learn more, see Generate an upgrade plan for single cluster and multiple clusters.
Note
For each cluster in a MetroCluster configuration, generate an individual upgrade plan for complete upgrade instructions.
Before generating an upgrade plan, you should prepare for an ONTAP upgrade. Proper preparation helps in identifying and mitigating potential upgrade risks or blockers before you begin the upgrade process. To learn more, see Prepare for an ONTAP upgrade.
