Your first API call
Contributors dmp-netapp
You can issue a simple curl command at your workstation’s CLI to get started using the Astra Control REST API and confirm its availability.
Before you begin
The Curl utility must be available on your local workstation. You must also have an API token and the associated account identifier. See Get an API token for more information.
Curl example
The following Curl command retrieves a list of Astra users. Provide the appropriate <ACCOUNT_ID> and <API_TOKEN> as indicated.
curl --location --request GET 'https://astra.netapp.io/accounts/<ACCOUNT_ID>/core/v1/users' --header 'Content-Type: application/json' --header 'Authorization: Bearer <API_TOKEN>'
JSON output example
  "items": [
    "David",
    "Anderson",
    "844ec6234-11e0-49ea-8434-a992a6270ec1"
      "Jane",
      "Cohen",
      "2a3e227c-fda7-4145-a86c-ed9aa0183a6c"
  "metadata": {}
