List all execution hooks
Retrieves all execution hooks, providing a JSON array of resources that match the specified criteria. Use this to view detailed information about each hook in the collection.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/executionHooks
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id" |
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: executionHook_1.2_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-executionHooks",
"version": "1.2",
"items": [
"type": "application/astra-executionHook",
"version": "1.1",
"id": "4c64792c-806b-4457-938d-8e325a37c593",
"name": "Payroll",
"hookType": "custom",
"matchingCriteria": [
"type": "containerImage",
"value": "payroll"
"type": "podName",
"value": "^payroll-master"
"action": "snapshot",
"stage": "pre",
"hookSourceID": "50e89023-ba84-435d-bb47-1833f4c250ff",
"arguments": [
"freeze"
"appID": "7be5ae7c-151d-4230-ac39-ac1d0b33c2a9",
"enabled": "true",
"description": "Payroll production hook",
"metadata": {
"labels": [],
"creationTimestamp": "2020-08-06T12:24:52.256624Z",
"modificationTimestamp": "2020-08-06T12:24:52.256624Z",
"createdBy": "64182074-ddb6-42eb-b7f4-b6a02cf9ba7c"
"version": "1.1",
"id": "6659892c-c621-44e8-a0bb-8dbdf378a2dd",
"name": "Order Processing",
"type": "containerName",
"value": "^order-processing$"
"type": "podLabel",
"value": "^app=master$|^app=data$"
"stage": "pre",
"hookSourceID": "63f4d6fd-b7f0-4eaa-9890-0b11123604b1",
"arguments": [
"freeze"
"enabled": "true",
"description": "Order processing hook",
"metadata": {
"labels": [],
"version": "1.1",
"name": "NetApp Postgres Hook",
"hookType": "netapp",
"type": "podName",
"value": "^postgres"
"value": "3.8"
"stage": "pre",
"hookSourceID": "3601ed09-1a74-4156-a1bd-9cb7144bac0e",
"arguments": [
"freeze"
"enabled": "true",
"metadata": {
"labels": [],
"version": "1.1",
"name": "Redis Hook",
"value": "^redis-01$"
"stage": "pre",
"arguments": [
"freeze"
"enabled": "true",
"metadata": {
"labels": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
matchingCriteria
type |
string |
True |
JSON string identifying the match criteria type. |
value |
string |
True |
JSON string containing a regex to match for the given match type. Regex syntax: https://github.com/google/re2/wiki/Syntax |
type_k8s_label
name |
string |
True |
value |
string |
True |
matchingContainers
podName |
string |
False |
JSON string of matching container's pod name. |
podLabels |
array[type_k8s_label] |
False |
JSON array of label objects of matching container's pod's labels. |
containerImage |
string |
False |
JSON string of matching container's image. |
containerName |
string |
False |
JSON string of matching container's name. |
namespaceName |
string |
False |
JSON string of matching container's pod's namespace name. |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-specified name for the resource. Defined values are:
hookType |
string |
True |
JSON string defining the hook type. Defined values are:
matchingCriteria |
array[matchingCriteria] |
True |
JSON array of JSON objects describing the match criteria for the execution hook. When multiple matchingCriteria are specified a logical AND is applied to criteria. Defined values are:
matchingContainers |
array[matchingContainers] |
False |
JSON array of JSON objects of each container that matches the configured matching criteria within the defined app. |
matchingImages |
array[string] |
False |
JSON array of JSON strings for the matching container images. Defined values are:
action |
string |
True |
JSON string indicating which action the execution hook will run assuming the match criteria are met. Defined values are:
stage |
string |
True |
JSON string indicating the stage during the action that the hook will be executed. Defined values are:
hookSourceID |
string |
True |
JSON string containing the hook source ID that is run through this execution hook. Defined values are:
arguments |
array[string] |
False |
JSON array of JSON strings for the arguments to the source. Defined values are:
appID |
string |
False |
JSON string containing the associated ID of the application that this hook is linked to. In essence, other matching criteria, if set. Defined values are:
enabled |
string |
True |
JSON string that indicates if the execution hook is enabled. Defined values are:
description |
string |
False |
JSON string containing a user-specified description for the hook source. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
