List the application assets for an application backup
Retrieves application assets for an application backup, providing a JSON array of all matching resources in the collection. Use this to view specific fields for each resource in the order specified.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/appBackups/{appBackup_id}/appAssets
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
appBackup_id |
string |
path |
True |
ID of the containing appBackup resource |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: appAsset_1.1_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-appAssets",
"version": "1.1",
"items": [
"Pod",
"mediawiki-69c6fcf864-2wx6l"
"ReplicaSet",
"mediawiki-69c6fcf864"
"Service",
"mediawiki"
"Deployment",
"mediawiki"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
GVK
JSON object containing a Kubernetes group/version/kind.
group |
string |
False |
JSON string containing a group identifier assigned by Kubernetes. Defined values are:
kind |
string |
False |
JSON string containing a kind identifier assigned by Kubernetes. Defined values are:
version |
string |
False |
JSON string containing a version identifier assigned by Kubernetes. Defined values are:
type_json
JSON object containing the entire content of the Kubernetes resource definition.
labels
name |
string |
True |
JSON string containing the label name Defined values are:
value |
string |
True |
JSON string containing the label value Defined values are:
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
assetType |
string |
True |
JSON string containing a value indicating what type of asset is being described as obtained from Kubernetes. Defined values are:
creationTimestamp |
string |
True |
JSON string containing a timestamp indicating when the Kubernetes metadata was created. Defined values are:
GVK |
True |
JSON object containing a Kubernetes group/version/kind. |
resource |
False |
JSON object containing the entire content of the Kubernetes resource definition. |
assetID |
string |
True |
JSON string containing an identifier assigned by Kubernetes. Defined values are:
labels |
array[labels] |
True |
JSON array of JSON objects, each containing a Kubernetes labels associated with the asset. If no details are available, this array will be empty.
assetName |
string |
True |
JSON string containing a name assigned by Kubernetes. Defined values are:
namespace |
string |
False |
JSON string containing a namespace assigned by Kubernetes. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
