Astra Automation
Create a new credential
Creates a new credential, specifying the desired values for the Credential API resource. Use this to manage access and authentication settings effectively.
HTTP method and endpoint
POST /accounts/{account_id}/core/v1/credentials
Usage notes
Indicates the desired values for the Credential API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
Request Body
type
string
True
  • "application/astra-credential"
version
string
True
  • "1.0"
  • "1.1"
name
string
True
JSON string containing a user-specified name. When a credential is created for a user, the name will be set to the UUID of that user. Defined values are:
  • Minimum length: 1
  • Maximum length: 127
keyType
string
False
JSON string containing an optional user-specified data validation type descriptor for the contents of the keyStore. Extended update constraints:
  • If a keyType does not exist in the resource and is not specified in an update, the keyType must not continue to exist in the updated resource.
  • If a keyType does not exist in the resource and is specified in an update, the keyType must be added to the resource and validation must be performed. If the validation fails, the update will fail.
  • If a keyType exists in the resource and is not specified in an update, the keyType must be preserved.
  • If a keyType exists in the resource and is specified in an update, and the keyType specified matches the existing keyType, the keyType must be preserved.
  • If a keyType exists in the resource and is specified in an update, and the keyType specified is different from the existing keyType, the update will fail. Defined values are:
  • "generic" - The credential is a generic collection of data. This is equivalent to not including a keyType.
  • Extended validation is performed as follows:
  • One or more strings must exist in the keyStore.
  • Every string in the keyStore must have a value encoded in base64.
  • "passwordHash" - The credential is a password hash.
  • The name of the credential must be unique.
  • The name of the credential must be equal to a valid user resource ID.
  • The name of the credential must not be altered.
  • The corresponding user resource must have an "authProvider" of "local".
  • A "cleartext" string must exist within the keyStore with a value containing a base64-encoded cleartext password:
  • The password cleartext must conform to the account's password policy.
  • The password is stored as a hash.
  • A "change" string must exist within the keyStore with a value containing a base64-encoded string "true" or "false".
  • A credential of type passwordHash can only be deleted if the user ID indicated by the name does not exist.
  • "apikey" - The credential is an API key.
  • An "apikey" string must exist within the keyStore, with a value containing a base64-encoded arbitrary string.
  • "kubeconfig" - The credential is a kubeconfig.
  • A "base64" string must exist within the keyStore, with a value containing a base64-encoded JSON kubeconfig file.
  • The kubeconfig file must only describe a single cluster.
  • No other fields can exist within the keyStore.
  • "certificate" - The credential is a PEM-encoded certificate
  • A "certificate" string must exist within the keyStore, with a value containing a base64-encoded PEM certificate.
  • "privkey" - The credential is a PEM-encoded private key.
  • A "privkey" string must exist within the keyStore, with a value containing a base64-encoded PEM private key.
  • "s3" - Indicates the credentials are for Simple Storage Service (S3) access.
  • An "accessKey" string must exist within the keyStore with a value containing a base64-encoded S3 access key.
  • An "accessSecret" string must exist within the keyStore with a value containing a base64-encoded S3 access secret.
keyStore
keyStore
True
JSON object containing JSON strings. Each string in the keyStore represents part of the credential. The name of each string represents the credential part, and the corresponding key-value stores the value of that part of the credential in base64 format. Defined values are:
  • Conforms to the base64 Encoded Data Schema No limits are placed on the lengths of the strings.
valid
string
False
JSON string describing whether the credential is valid for use. Default value, if omitted, is "true". Defined values are:
  • "true" - The credential is eligible for use.
  • "false" - The credential must not be used.
validFromTimestamp
string
False
JSON string containing a timestamp indicating when the credential is valid. These are used for credential rotation. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
validUntilTimestamp
string
False
JSON string containing a timestamp indicating when the credential is no longer valid. These are used for credential rotation. Defined values are:
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-credential",
  "version": "1.1",
  "name": "myCert",
  "keyStore": {
    "privKey": "SGkh",
    "pubKey": "VGhpcyBpcyBhbiBleGFtcGxlLg=="
Status: 201, Returns the newly created credential resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
  • Minimum length: 1
keyType
string
False
valid
string
True
validFromTimestamp
string
False
validUntilTimestamp
string
False
metadata
True
  "version": "1.1",
  "id": "58e26f6a-a631-5122-8e0e-7afe306675c0",
  "name": "myCert",
  "valid": "true",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
keyStore
Hash mapping strings to string
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
