Create a new credential
POST /accounts/{account_id}/core/v1/credentials
Indicates the desired values for the Credential API resource to be created.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
Request Body
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
name |
string |
True |
JSON string containing a user-specified name. When a credential is created for a user, the name will be set to the UUID of that user. Defined values are:
keyType |
string |
False |
JSON string containing an optional user-specified data validation type descriptor for the contents of the keyStore. Extended update constraints:
keyStore |
True |
JSON object containing JSON strings. Each string in the keyStore represents part of the credential. The name of each string represents the credential part, and the corresponding key-value stores the value of that part of the credential in base64 format. Defined values are:
valid |
string |
False |
JSON string describing whether the credential is valid for use. Default value, if omitted, is "true". Defined values are:
validFromTimestamp |
string |
False |
JSON string containing a timestamp indicating when the credential is valid. These are used for credential rotation. Defined values are:
validUntilTimestamp |
string |
False |
JSON string containing a timestamp indicating when the credential is no longer valid. These are used for credential rotation. Defined values are:
metadata |
False |
Example request
"type": "application/astra-credential",
"version": "1.1",
"name": "myCert",
"keyStore": {
"privKey": "SGkh",
"pubKey": "VGhpcyBpcyBhbiBleGFtcGxlLg=="
Status: 201, Returns the newly created credential resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
keyType |
string |
False |
valid |
string |
True |
string |
False |
string |
False |
metadata |
True |
"version": "1.1",
"id": "58e26f6a-a631-5122-8e0e-7afe306675c0",
"name": "myCert",
"valid": "true",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
keyStore
Conforms to the base64 Encoded Data Schema No limits are placed on the lengths of the strings.
Hash mapping strings to string
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
