Astra Automation
Add LDAP entries to Astra
Contributors dmp-netapp
After LDAP is configured as an authentication provider for Astra Control Center, you can select the LDAP users that Astra will authenticate using the LDAP credentials. Each user must have a role in Astra before they can access Astra through the Astra Control REST API.
There are two ways you can configure Astra to assign roles. Choose the one that is appropriate for your environment.
Note The LDAP credentials are in the form of a username as an email address and the associated LDAP password.
Add and bind an individual user
You can assign a role to each Astra user which is used after LDAP authentication. This is appropriate when there is a small number of users and each might have different administrative characteristics.
1. Add a user
Perform the following REST API call to add a user to Astra and indicate that LDAP is the authentication provider.
HTTP method Path
POST
/accounts/{account_id}/core/v1/users
JSON input example
  "type" :  "application/astra-user",
  "version" : "1.1",
  "authID" : "cn=JohnDoe,ou=users,ou=astra,dc=example,dc=com",
  "authProvider" : "ldap",
  "firstName" : "John",
  "lastName" : "Doe",
  "email" : "john.doe@example.com"
Note the following about the input parameters:
  • The following parameters are required:
    • authProvider
    • authID
    • email
  • authID is the distinguished name (DN) of the user in LDAP
  • email must be unique for all users defined in Astra
If the email value is not unique, an error occurs and a 409 HTTP status code is returned in the response.
Curl example
curl --location -i --request POST --data @JSONinput 'https://astra.example.com/accounts/<ACCOUNT_ID>/core/v1/users' --header 'Content-Type: application/astra-user+json' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>'
JSON response example
  "metadata": {
    "creationTimestamp": "2022-07-21T17:44:18Z",
    "modificationTimestamp": "2022-07-21T17:44:18Z",
    "createdBy": "8a02d2b8-a69d-4064-827f-36851b3e1e6e",
    "labels": []
  "type": "application/astra-user",
  "version": "1.2",
  "id": "a7b5e674-a1b1-48f6-9729-6a571426d49f",
  "authProvider": "ldap",
  "authID": "cn=JohnDoe,ou=users,ou=astra,dc=example,dc=com",
  "firstName": "John",
  "lastName": "Doe",
  "companyName": "",
  "email": "john.doe@example.com",
  "postalAddress": {
    "addressCountry": "",
    "addressLocality": "",
    "addressRegion": "",
    "streetAddress1": "",
    "streetAddress2": "",
    "postalCode": ""
  "state": "active",
  "sendWelcomeEmail": "false",
  "isEnabled": "true",
  "isInviteAccepted": "true",
  "enableTimestamp": "2022-07-21T17:44:18Z",
  "lastActTimestamp": ""
2. Add a role binding for the user
Perform the following REST API call to bind the user to a specific role. You need to have the UUID of the user created in the previous step.
HTTP method Path
POST
/accounts/{account_id}/core/v1/roleBindings
JSON input example
  "type": "application/astra-roleBinding",
  "version": "1.1",
  "accountID": "{account_id}",
  "userID": "a7b5e674-a1b1-48f6-9729-6a571426d49f",
  "role": "member",
  "roleConstraints": ["*"]
  • The value used above for roleConstraint is the only option available for the current release of Astra. It indicates the user is not restricted to a limited set of namespaces and can access them all.
Curl example
curl --location -i --request POST --data @JSONinput 'https://astra.example.com/accounts/<ACCOUNT_ID>/core/v1/roleBindings' --header 'Content-Type: application/astra-roleBinding+json' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>'
  "metadata": {
    "creationTimestamp": "2022-07-21T18:08:24Z",
    "modificationTimestamp": "2022-07-21T18:08:24Z",
    "labels": []
  "principalType": "user",
  "version": "1.1",
  "id": "b02c7e4d-d483-40d1-aaff-e1f900312114",
  "groupID": "00000000-0000-0000-0000-000000000000",
  "accountID": "d0fdbfa7-be32-4a71-b59d-13d95b42329a",
  "role": "member",
Note the following about the response parameters:
  • The value user for the principalType field indicates the role binding was added for a user (not a group).
Add and bind a group
You can assign a role to an Astra group which is used after LDAP authentication. This is appropriate when there is a large number of users and each might have similar administrative characteristics.
1. Add a group
Perform the following REST API call to add a group to Astra and indicate that LDAP is the authentication provider.
HTTP method Path
POST
/accounts/{account_id}/core/v1/groups
JSON input example
  "type": "application/astra-group",
  "version": "1.0",
  "name": "Engineering",
  "authID": "CN=Engineering,OU=groups,OU=astra,DC=example,DC=com"
    • authProvider
    • authID
Curl example
curl --location -i --request POST --data @JSONinput 'https://astra.example.com/accounts/<ACCOUNT_ID>/core/v1/groups' --header 'Content-Type: application/astra-group+json' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>'
  "version": "1.0",
  "id": "8b5b54da-ae53-497a-963d-1fc89990525b",
  "authID": "CN=Engineering,OU=groups,OU=astra,DC=example,DC=com",
  "metadata": {
    "creationTimestamp": "2022-07-21T18:42:52Z",
    "modificationTimestamp": "2022-07-21T18:42:52Z",
    "labels": []
2. Add a role binding for the group
Perform the following REST API call to bind the group to a specific role. You need to have the UUID of the group created in the previous step. Users that are members of the group will be able to sign in to Astra after LDAP performs the authentication.
HTTP method Path
POST
JSON input example
  "version": "1.1",
  "groupID": "8b5b54da-ae53-497a-963d-1fc89990525b",
  "role": "viewer",
  • The value used above for roleConstraint is the only option available for the current release of Astra. It indicates the user is not restricted to certain namespaces and can access them all.
Curl example
  "metadata": {
    "creationTimestamp": "2022-07-21T18:59:43Z",
    "modificationTimestamp": "2022-07-21T18:59:43Z",
    "createdBy": "527329f2-662c-41c0-ada9-2f428f14c137",
    "labels": []
  "principalType": "group",
  "version": "1.1",
  "id": "2f91b06d-315e-41d8-ae18-7df7c08fbb77",
  "userID": "00000000-0000-0000-0000-000000000000",
  "role": "viewer",
  • The value group for the principalType field indicates the role binding was added for a group (not a user).
