Retrieve an entitlement
GET /accounts/{account_id}/core/v1/entitlements/{entitlement_id}
Returns the stored Entitlement API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
entitlement_id
string
path
True
ID of the entitlement collection to list
Status: 200, Returns the stored Entitlement API resource in the JSON response body.
type
string
True
  • "application/astra-entitlement"
version
string
True
  • "1.0"
id
string
True
allocation
string
False
JSON string containing the ID of the object that the entitlement is allocated to. Only present when the entitlement is allocated. String contents not validated by the schema.
product
string
False
JSON string containing the product string extracted from the license or subscription. String contents not validated by the schema.
productVersion
string
False
JSON string containing the version string extracted from the license or subscription. String contents not validated by the schema.
entitlementType
string
True
JSON string containing the type of the entitlement. This is extracted from the license or subscription. String contents not validated by the schema.
entitlementValue
string
True
JSON string containing the capacity associated with the entitlement. String contents not validated by the schema.
entitlementConsumption
string
False
JSON string containing the amount of the capacity associated with the entitlement that is currently in use. String contents not validated by the schema.
sourceLicense
string
False
JSON string containing the license object ID that the entitlement is sourced from. Defined values are:
  • Conforms to the Astra Identifier Schema
sourceSubscription
string
False
JSON string containing the ID of the subscription object that the entitlement is sourced from. Defined values are:
validFromTimestamp
string
False
JSON string containing a timestamp indicating when the entitlement becomes valid. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
validUntilTimestamp
string
False
JSON string containing a timestamp indicating when the entitlement is no longer valid. Defined values are:
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-entitlement",
  "version": "1.0",
  "id": "8bdafc19-bde6-5f45-9808-4893c845c9f5",
  "product": "Astra SDS",
  "productVersion": "1.0",
  "entitlementType": "capacity",
  "entitlementValue": "2",
  "entitlementConsumption": "1",
  "sourceLicense": "c8aa757a-5318-489f-8134-a2a1a6956a3e",
  "validFromTimestamp": "2020-08-06T00:00:00.000000Z",
  "validUntilTimestamp": "2021-08-06T00:00:00.000000Z",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
