Retrieve a subscription
GET /accounts/{account_id}/core/v1/subscriptions/{subscription_id}
Returns the stored Subscription API resource in the JSON response body.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
subscription_id |
string |
path |
True |
ID of the subscription collection to list |
Status: 200, Returns the stored Subscription API resource in the JSON response body.
Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
customerProfileID |
string |
True |
JSON string containing the customer profile ID from Authorize.net, which was invoked by the UI, is not set for the trial term. Returns an empty string during read operation, if not set. Defined values are:
paymentProfileID |
string |
False |
JSON string containing the payment profile ID from Authorize.net that was invoked by the UI, not set for trial term. Returns an empty string during read operation if not set. Defined values are:
paymentExpiry |
string |
False |
JSON string containing a timestamp indicating when the payment method expires. This is obtained from authorize.net](http://authorize.net) and is set by the UI. Defined values are:
purchaseOrderNumber |
string |
False |
JSON string containing the purchase order number for the payment method. Defined values are:
marketplace |
string |
False |
JSON string indicating the marketplace for an account where payments will be recorded. Defined values:
licenseSN |
string |
False |
JSON string containing the license serial number for the payment method. Defined values are:
terms |
string |
True |
JSON string indicating the current tier of the account. Defined values are:
status |
string |
True |
JSON string indicating the current status of the subscription. Defined values are:
appLimit |
number |
True |
JSON number indicating the application limit for this subscription. Value of -1 indicates no limit. |
namespaceLimit |
number |
True |
JSON number indicating the namespace limit for this subscription. Value of -1 indicates no limit. |
subscriptionPeriod |
number |
True |
JSON number indicating the subscription period. Value of -1 indicates no limit. Unit: days |
gracePeriod |
number |
True |
JSON number indicating the grace period after the trial subscription has expired or a paid subscription is canceled. Unit: days |
reminderBeforePeriod |
number |
True |
JSON number indicating the number of days before the end of the trial subscription when the customer notifications will begin. The value is expressed in days with a value of -1 indicating it's not applicable. |
onboardStatus |
string |
True |
JSON string indicating the current status of customer onboarding. Valid values are "not started", "in progress", "success", "failed". Defined values are:
costPerAppUnit |
number |
True |
JSON number indicating the cost per app unit. For a trial version, the value is 0. Unit: US dollars |
costPerNamespaceUnit |
number |
True |
JSON number indicating the cost per namespace unit. For a trial version, the value is 0. Unit: US dollars |
metadata |
True |
"type": "application/astra-subscription",
"version": "1.2",
"id": "40b4106f-b743-5d83-95c7-d539b2b45f63",
"customerProfileID": "2157047189",
"paymentProfileID": "E7CEB0A9F1BECA32A02493E1B31D5955",
"paymentExpiry": "2022-02-01T00:00:00Z",
"purchaseOrderNumber": "72384632",
"marketplace": "netapp",
"licenseSN": "278343",
"terms": "trial",
"status": "active",
"onboardStatus": "success",
"costPerAppUnit": 0,
"costPerNamespaceUnit": 0.005,
"appLimit": 0,
"namespaceLimit": 10,
"subscriptionPeriod": 90,
"gracePeriod": 7,
"reminderBeforePeriod": 30,
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
