Astra Automation
List groups for a user
Retrieves a list of groups associated with a user, providing access to detailed group information for management or analysis purposes.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/users/{user_id}/groups
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
user_id
string
path
True
ID of the containing user resource
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,authProvider,authID
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
filter
string
query
False
Indicates which fields should be matched in order to return a resource when listing a collection.
Supported operators are:
  • eq - Equality
  • lt/gt - Less than/Greater than
  • lte/gte - Less than or equals to/Greater than or equals to
URL example: "filter=field%20eq%20%27value%27"
OpenAPI examples: "field eq 'value'"
orderBy
string
query
False
Indicates the sort order of resource when listing a collection.
URL examples: "orderBy=name", "orderBy=name%20desc"
OpenAPI examples: "name desc"
skip
string
query
False
Indicates the number of resources to skip over when listing a collection.
URL examples: "skip=1"
OpenAPI examples: "1"
count
string
query
False
Indicates if the total number of resources should be returned in the metadata object.
URL examples: "count=true"
OpenAPI examples: "true"
continue
query
False
Indicates the token to resume listing from.
URL examples: "continue="
OpenAPI examples: ""</continue>
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: group_1.1_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-groups",
  "version": "1.1",
  "items": [
      "11c0cfa1-4f27-4ef7-a21c-cb452fc5c9aa",
      "ldap",
      "CN=Testers,CN=groups,DC=example,DC=com"
      "e324ec3a-706d-4f57-a95d-1d88c03e7b73",
      "ldap",
      "CN=Admins,CN=groups,DC=example,DC=com"
      "3070c84d-129b-4017-82a8-2c26a42dd77e",
      "ldap",
      "CN=SREs,CN=groups,DC=example,DC=com"
  "metadata": {
    "labels": [],
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 500, Internal server error
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/34",
  "title": "Internal server error",
  "detail": "The server was unable to process this request.",
  "status": "500"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
type_astra_label
name
string
True
value
string
True
type_astra_metadata_update
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
type
string
True
  • "application/astra-group"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
The name of the group resource. If not specified on create, the value will be set to
  • first Common Name (CN) Relative Distinguished Names (RDN) if found in the authID,
  • authID, otherwise. If not specified on update, the value will be preserved without modification. Defined values are:
  • Minimum length: 1
  • Maximum length: 2048
authProvider
string
True
The authentication provider for the group resource. Defined values are:
  • "ldap"
authID
string
True
The Distinguished Name (DN) for an LDAP group. Defined values are:
  • Minimum length: 1
metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
