List groups for a user
Retrieves a list of groups associated with a user, providing access to detailed group information for management or analysis purposes.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/users/{user_id}/groups
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
user_id |
string |
path |
True |
ID of the containing user resource |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
orderBy |
string |
query |
False |
Indicates the sort order of resource when listing a collection. URL examples: "orderBy=name", "orderBy=name%20desc" OpenAPI examples: "name desc" |
skip |
string |
query |
False |
Indicates the number of resources to skip over when listing a collection. URL examples: "skip=1" OpenAPI examples: "1" |
count |
string |
query |
False |
Indicates if the total number of resources should be returned in the metadata object. URL examples: "count=true" OpenAPI examples: "true" |
continue |
query |
False |
Indicates the token to resume listing from. URL examples: "continue= OpenAPI examples: " |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: group_1.1_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-groups",
"version": "1.1",
"items": [
"11c0cfa1-4f27-4ef7-a21c-cb452fc5c9aa",
"ldap",
"CN=Testers,CN=groups,DC=example,DC=com"
"e324ec3a-706d-4f57-a95d-1d88c03e7b73",
"ldap",
"CN=Admins,CN=groups,DC=example,DC=com"
"3070c84d-129b-4017-82a8-2c26a42dd77e",
"ldap",
"CN=SREs,CN=groups,DC=example,DC=com"
"metadata": {
"labels": [],
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/34",
"title": "Internal server error",
"detail": "The server was unable to process this request.",
"status": "500"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
The name of the group resource. If not specified on create, the value will be set to
authProvider |
string |
True |
The authentication provider for the group resource. Defined values are:
authID |
string |
True |
The Distinguished Name (DN) for an LDAP group. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
